EPG - Multiple copies
Server Version#: 1.41.0.8994
Player Version#: N/A
Tuner Make/Model: Hauppauge QuadHD PCIe
Guide/Lineup name: Local Broadcast Listings (94 Channels)
Using XMLTV?: No
Channel number/Name: All
When assigning a detected channel to a guide entry using the dropdown, I currently have four lists to select from with essentially all the same channels:
  • Local Broadcast Listings (94 Channels)
  • Local Broadcast Listings (93 Channels)
  • Local Broadcast Listings (90 Channels)
  • Local Broadcast Listings (76 Channels)
    How can I clean up the EPG drop down? I’d expect that there should only be one set of guide data to select from and am assuming that any differences in the lists are due to signal strength when scanning?
