Server Version#: 1.25.2.5319
Player Version#: Plex Web 4.72.0 / Plex for Windows 1.39.1.2763-300bb607
Tuner Make/Model: HDHomeRun CONNECT QUATRO
Guide/Lineup name: Local Broadcast Listings (Albuquerque, NM, USA)
Using XMLTV?: No
Channel number/Name:
I’m having an issue where if the EPG has multiple listings for the same channel number, I can’t select the correct number from the list.
Selecting the second “5.5” in the list above will always revert back to the first entry which isn’t correct in my area. From what I can tell, it looks like the interface is choosing the channel number which doesn’t work when there are duplicates. This is an issue because the guide loads the wrong show information and therefor makes the DVR unusable for that channel.
Has anyone else seen this and, if so, fixed it?
