EPG refresh hangs (since any days at 9%)
Hello,
my EPG refresh hangs since many days at 9% - is it possible to “reset” (at the best without lost of configuration - i had 32 senders sort out from 425, and then sort to specific senders)?
Thanks a lot for your help.
Which is your pms version? The last beta faced a bug on EPG refresh.
You can: wait the next release (will arrive soon) or try to reset the epg data or remove/add again the dvr.
Thanks Comio, is it possible to save the Channel-Configuration? So i can restore it after Reset and reload the EPG.
Thanks.
Plex will provide a new version soon. Just wait. See my bug report
Ok, thanks :).
Did i need the Beta or is it in the stable Brunch too?
beta. I don’t know plex’s release scheduling.
Ok, then i switch to the Beta Channel and waiting for Updates.
Thanks a lot.
Updates are doesn’t show - so i update manualy. Now the EPG Refresh works fine (now at 24%, before this it hangs on 9%).
So the problem is solved.
Thanks a lot for your Support.
