EPG: Season incorrectly identified
HI All,
Can someone explain how the XML schema for XMLTV works? I use a free service that provide much quicker EPG data than using the Plex provided EPG. However, the season and episodes are mixed up.
For example:
	<programme start="20170915090000 +0000" stop="20170915093000 +0000" channel="ABCHD">
		<title>ABC News</title>
		<desc>The latest news, breaking news and live coverage of events as they happen from Australia's largest broadcast news network. Comprehensive coverage, original reporting, and analysis of news in Australia.</desc>
		<category>News</category>
		<category>Weather</category>
		<category>News and Business</category>
		<category>Live</category>
		<subtitles type="teletext" />
		<rating>
			<value>PG</value>
		</rating>
		<star-rating>
			<value>0/10</value>
		</star-rating>
		<episode-num system="xmltv_ns">2017 . 221 . 0</episode-num>
		<episode-num system="bsepg-epid">SE-NN1707V . EP-221S00</episode-num>
	</programme>
Plex identifies this ABC News episode as “2018·E221—Episode 221”. Why is it not identifying it as 2017 EP 221?
Is this a fault in Plex or is the xml data incorrect?
Sounds like you are down under…
See this post for same issue and fix.
thanks nokdim for your answer. You are correct; I am in Australia.
I had a look at those posts. mc2xml doesn’t support Au unfortunately. I don’t really want to pay for IceTV when I could use the service already provided by Plex (but it is very very slow).
I’m using a service provided by http://freepg.tv.
I had a play around with the xml, and it seems that the series in the xml tag is incorrect. It is tagged like:
2017 . 181 . 0
However, according to the xmltv dtd, the series is numbered from zero. So, Plex is reading the series number as 2018. It should be 2016 . 181 . 0 in this example.
I’ve scripted a fix, but will contact the providers to see if that can be changed in the xml
