Mine goes to 100% and then stays stuck, been this way for over 24 hours now.
Please could you provide logs of the problem
Ensure debug logging is enabled
See https://support.plex.tv/articles/201643703-reporting-issues-with-plex-media-server/
Restart the server and when you get the problem please note down the time, take a screenshot and download the logs and attach the zip and screenshot in a post here
For logs See https://support.plex.tv/articles/200250417-plex-media-server-log-files/
And please attach the screenshots here in your forum post and do not put it on a web site that insists on installing loads of third party cookies to whoever wants to view the screenshot
Thanks for the logs. There appears to be database corruption which is causing failures during the optimization at the end of the EPG refresh
have a look at the support articles for db repair and restore from backup
https://support.plex.tv/articles/201100678-repair-a-corrupt-database/
https://support.plex.tv/articles/202485658-restore-a-database-backed-up-via-scheduled-tasks/
@deadman36g I have moved your posts and my replies to a separate forum topic (here) as the issue is different from what is covered in forum thread EPG fails to update
@deadman36g
Examples of the corruptions
Sep 16, 2018 19:53:48.250 [0x7f6e0cffa700] ERROR - SQLITE3:0x10, 6410, statement aborts at 2341: [select distinct media_items.id as 'media_items_id', media_items.library_section_id as 'media_items_library_section_id', media_items.section_location_id as 'media_items_section_locati
Sep 16, 2018 19:53:48.253 [0x7f6e0cffa700] ERROR - Soci Exception handled: sqlite3_statement_backend::loadRS: disk I/O error
Sep 16, 2018 22:24:13.166 [0x7f0627bfe700] ERROR - SQLITE3:0x10, 6410, statement aborts at 84: [delete from tags where tags.tag_type != ? and tags.tag_type != ? and tags.id in (select tags.id from tags left join taggings on taggings.tag_id=tags.id group by tags.id having count(ta
Sep 16, 2018 22:24:13.181 [0x7f0627bfe700] ERROR - Exception inside transaction (inside=1) (../Library/DatabaseFixups.cpp:207): sqlite3_statement_backend::loadOne: disk I/O error
Other Info:
The logs do also show other issues that you need to look into
Reached max default limit for Notidy watched directories (8192)
Sep 16, 2018 22:20:57.972 [0x7f06323ff700] DEBUG - [Notify] Now watching /tv/gdrive/The Sopranos/The.Sopranos.S05.1080p.Bluray.DD5.1.x264-EbP
Sep 16, 2018 22:20:57.979 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Sopranos/The.Sopranos.S06.1080p.BluRay.DD5.1.x264-DON (28: No space left on device)
Sep 16, 2018 22:20:57.989 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Tick (28: No space left on device)
Sep 16, 2018 22:20:57.991 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Tick/Season 1 (28: No space left on device)
Sep 16, 2018 22:20:58.007 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Tick/Season 2 (28: No space left on device)
Sep 16, 2018 22:20:58.025 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Tick/Season 3 (28: No space left on device)
Sep 16, 2018 22:20:58.043 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Torkelsons (28: No space left on device)
Sep 16, 2018 22:20:58.045 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Torkelsons/Season 1 (28: No space left on device)
Sep 16, 2018 22:20:58.054 [0x7f06323ff700] ERROR - [Notify] Failed to add watch for /tv/gdrive/The Torkelsons/Season 2 (28: No space left on device)
+ many more such errors
See this post for similar issue
and Permissions issue on /tmp
Sep 16, 2018 22:20:20.099 [0x7f063fd17d40] WARN - Failed to create temp dir "/tmp/pms-7b0fdc0e-93b4-4c4f-a7ff-71f7f3123c71": 13, Permission denied
Sep 16, 2018 22:27:26.837 [0x7f061d3ff700] ERROR - Error creating directory "/tmp/tempLogs7c425ec4-07e9-486d-93a3-0dd5ca205dfe": boost::filesystem::create_directory: Permission denied: "/tmp/tempLogs7c425ec4-07e9-486d-93a3-0dd5ca205dfe"
Sep 16, 2018 22:27:26.837 [0x7f061d3ff700] ERROR - Error creating directory "/tmp/tempLogs7c425ec4-07e9-486d-93a3-0dd5ca205dfe/PMS Plugin Logs": boost::filesystem::create_directories: Permission denied: "/tmp/tempLogs7c425ec4-07e9-486d-93a3-0dd5ca205dfe"
Sep 16, 2018 22:27:58.608 [0x7f06107fd700] ERROR - Error creating directory "/tmp/tempLogsd6a839d5-bbce-4d1b-9990-28056adada8f": boost::filesystem::create_directory: Permission denied: "/tmp/tempLogsd6a839d5-bbce-4d1b-9990-28056adada8f"
Sep 16, 2018 22:27:58.608 [0x7f06107fd700] ERROR - Error creating directory "/tmp/tempLogsd6a839d5-bbce-4d1b-9990-28056adada8f/PMS Plugin Logs": boost::filesystem::create_directories: Permission denied: "/tmp/tempLogsd6a839d5-bbce-4d1b-9990-28056adada8f"
and similar
Sep 16, 2018 22:28:05.416 [0x7f06323ff700] WARN - Diagnostics: Could not open zip "/tmp/logs.zip2be6d799-f85f-40f0-82e3-ac29c44c4fc2" for write
Sep 16, 2018 22:28:05.417 [0x7f06323ff700] WARN - Diagnostics: Error zipping files for Plex Media Server Databases_2018-09-16_22-28-05.zip
Sep 16, 2018 22:28:05.417 [0x7f0630bfe700] DEBUG - Completed: [192.168.1.143:61937] 500 GET /diagnostics/databases (9 live) GZIP 24314ms 405 bytes (pipelined: 7)
Ok, I have made a few changes and was hoping you could check my logs and see if everything looks good.
I followed the following guide
on increasing inotify
I added /tmp to my PLEX docker container
Also, since upgrading my PMS (Version 1.13.8.5388) my guide seems to be working correctly as well
All looks good !
Awesome Thanks man
