Currently running PMS .9.8.14 on winxp...Everything was working fine and then now this, see error message below.
I also cannot connect to the PMS using http://127.0.0.1:32400/web/index.html#!/dashboard. Firefox just says it cannot load page and so does Safari.
I've turned off Firewall. I've used the wiki instructions on how to remove pms completely and did a clean install. Nothing has worked.
Willing to take any suggestions here.
21:19:16 PlexAPI: ***
21:19:16 PlexAPI: looking up Plex Media Server
21:19:17 PlexAPI: GDM: Servers discovered: 2
21:19:18 PlexAPI: Servers (local+MyPlex): 3
21:19:18 WebServer: serving .xml: /
21:19:23 WebServer: serving .xml: /channels/all
21:19:25 PlexAPI: No Response from Plex Media Server
21:19:25 PlexAPI: We failed to reach a server. Reason: [Errno 10061] No connecti
on could be made because the target machine actively refused it
21:19:26 PlexAPI: No Response from Plex Media Server
21:19:26 PlexAPI: We failed to reach a server. Reason: [Errno 10061] No connecti
21:19:27 PlexAPI: No Response from Plex Media Server
21:19:27 PlexAPI: We failed to reach a server. Reason: [Errno 10061] No connecti
21:19:27 WebServer: serving /js/utils.js
21:19:29 WebServer: serving .xml: /library/sections
21:19:30 PlexAPI: No Response from Plex Media Server
21:19:30 PlexAPI: We failed to reach a server. Reason: [Errno 10061] No connecti
21:19:30 WebServer: serving /js/utils.js
