Estou tendo problemas ao tentar reproduzir um vídeo, sempre aparece esta mensagem:
Alguém pode me ajudar?
Obrigado.
Vá em configurações > geral e habilite debug logs. Reproduza o problema e anexe os logs aqui
Segue o pacote dos Logs
com.plexapp.agents.fanarttv.log (12.1 KB) com.plexapp.agents.htbackdrops.log (7.4 KB) com.plexapp.agents.imdb.log (5.9 KB) com.plexapp.agents.lastfm.log (7.4 KB) com.plexapp.agents.localmedia.log (17.6 KB) com.plexapp.agents.lyricfind.log (4.9 KB) com.plexapp.agents.movieposterdb.log (4.8 KB) com.plexapp.agents.none.log (14.6 KB) com.plexapp.agents.opensubtitles.log (6.7 KB) com.plexapp.agents.plexthememusic.log (5.0 KB) com.plexapp.agents.themoviedb.log (7.9 KB) com.plexapp.agents.thetvdb.log (4.9 KB) com.plexapp.system.log (42.4 KB) org.musicbrainz.agents.music.log (7.1 KB) Plex Crash Uploader.2.log (177 Bytes) Plex Crash Uploader.4.log (177 Bytes) Uploading: Plex Crash Uploader.5.log… Uploading: Plex Crash Uploader.log… Plex Media Scanner Analysis.1.log (3.8 KB) Plex Media Scanner Analysis.2.log (3.8 KB) Plex Media Scanner Analysis.3.log (3.8 KB) Plex Media Scanner Analysis.4.log (3.8 KB) Plex Media Scanner Analysis.5.log (3.8 KB) Plex Media Scanner Analysis.log (4.0 KB) Plex Media Scanner Chapter Thumbnails.1.log (30.4 KB) Plex Media Scanner Chapter Thumbnails.2.log (26.9 KB) Plex Media Scanner Chapter Thumbnails.3.log (38.1 KB) Plex Media Scanner Chapter Thumbnails.4.log (32.0 KB) Plex Media Scanner Chapter Thumbnails.5.log (38.9 KB) Plex Media Scanner Chapter Thumbnails.log (35.1 KB) Plex Media Scanner Deep Analysis.1.log (8.2 KB) Plex Media Scanner Deep Analysis.2.log (11.3 KB) Plex Media Scanner Deep Analysis.3.log (14.1 KB) Plex Media Scanner Deep Analysis.4.log (13.7 KB) Plex Media Scanner Deep Analysis.5.log (2.2 KB) Plex Media Scanner Deep Analysis.log (10.7 KB) Plex Media Scanner Matcher.1.log (1.6 KB) Plex Media Scanner Matcher.2.log (2.2 KB) Plex Media Scanner Matcher.3.log (2.0 KB) Plex Media Scanner Matcher.4.log (2.0 KB) Plex Media Scanner Matcher.5.log (2.2 KB) Plex Media Scanner Matcher.log (2.0 KB) Plex Media Scanner.1.log (104.4 KB) Plex Media Scanner.2.log (26.0 KB) Plex Media Scanner.3.log (104.0 KB) Plex Media Scanner.4.log (299.7 KB) Plex Media Scanner.5.log (105.3 KB) Plex Media Scanner.log (85.9 KB) Plex Media Server.2.log (4.5 MB) Plex Media Server.log (3.3 MB) Uploading: Plex Transcoder Statistics.4.log… Uploading: Plex Transcoder Statistics.log… Uploading: Plex Tuner Service.2.log… Uploading: Plex Tuner Service.5.log… Uploading: Plex Tuner Service.log… Uploading: Plex Update Service Launcher.2.log… Uploading: Plex Update Service Launcher.3.log… Uploading: Plex Update Service Launcher.4.log… Uploading: Plex Update Service Launcher.log… Uploading: Plex Update Service.1.log… Uploading: Plex Update Service.2.log… Uploading: Plex Update Service.3.log… Uploading: Plex Update Service.5.log…
Habilite somente o debug, não o verbose. E quando receber o erro, poste o arquivo .zip aqui.
Segue o arquivo Plex Media Server Logs_2021-03-31_23-10-37.zip (1.3 MB)
Primeira coisa, desabilite o wifi de seu servidor. Ele está comutando de uma interface para outra. Deixe apenas a interface com IP 192.168.0.10 habilitada e reinicie o serviço Plex.
Settings > Network > Preferred network interface selecione sua interface com IP final .10.
Vejo que você está tentando rodar o filme em um navegador e não em um cliente Plex, e outras pessoas estão se queixando de um erro similar ao seu mas de qualquer forma vá em Settings > Transcoder e se certifique que Disable transcode está Desmarcado.
Me deixe saber se algo mudou
Alterei a interface do IP e a opção do Transcoder já estava desmarcada.
Salvei e reiniciei o PC e mesmo assim não resolveu o problema.
Segue o arquivo Plex Media Server Logs_2021-04-01_14-35-14.zip (954.9 KB)
Apr 01, 2021 14:34:56.371 [8348] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 (2006) [1080p]\300.2006.BluRay.1080p.x264.YIFY.mp4: Bad file descriptor
Apr 01, 2021 14:34:56.384 [13888] DEBUG - Jobs: 'C:\Program Files (x86)\Plex\Plex Media Server\Plex Transcoder.exe' exit code for process 8912 is 1 (failure)
Apr 01, 2021 14:34:56.384 [9420] DEBUG - [Transcode] Using default transcode duration of 120 minutes
Apr 01, 2021 14:34:56.384 [4520] DEBUG - Streaming Resource: Terminated session 0x5667e58:4dgbg6jh9dpqvmrmoxavlofp with reason Conversion failed. The transcoder exited due to an error.
Seu arquivo de vídeo está corrompido
Alguma coisa está acontecendo no seu HD, você tem mais de um arquivo corrompido
Mar 21, 2021 11:27:54.631 [14112] ERROR - Match: Caught exception opening file: Could not parse P:\FILMES\PlexHD\FILMES\A.I.Artificial.Intelligence.2001.1080p.Bluray.x264.anoXmous\A.I.Artificial.Intelligence.2001.1080p.Bluray.x264.anoXmous.mp4 (error=-9): Bad file descriptor
Mar 21, 2021 11:27:24.333 [3128] ERROR - Match: Caught exception opening file: Could not parse P:\FILMES\PlexHD\FILMES\Interstellar (2014) (2014) [1080p]\Interstellar.2014.2014.1080p.BluRay.x264.YIFY.mp4 (error=-9): Bad file descriptor
Mar 21, 2021 11:27:19.106 [2332] ERROR - Match: Caught exception opening file: Could not parse P:\FILMES\PlexHD\FILMES\Interstellar (2014) (2014) [1080p]\Interstellar.2014.2014.1080p.BluRay.x264.YIFY.mp4 (error=-9): Bad file descriptor
Mar 21, 2021 11:26:02.246 [13712] ERROR - Match: Caught exception opening file: Could not parse P:\FILMES\PlexHD\FILMES\A.I.Artificial.Intelligence.2001.1080p.Bluray.x264.anoXmous\A.I.Artificial.Intelligence.2001.1080p.Bluray.x264.anoXmous (1).mp4 (error=-9): Bad file descriptor
Mar 21, 2021 11:31:13.859 [13392] ERROR - Match: Caught exception opening file: Could not parse P:\FILMES\PlexHD\FILMES\Slumdog Millionaire (2008) [1080p]\Slumdog.Millionaire.2008.1080p.BluRay.x264.YIFY.mp4 (error=-9): Bad file descriptor
Apr 01, 2021 00:12:48.460 [0472] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 (2006) [1080p]\300.2006.BluRay.1080p.x264.YIFY.mp4: Bad file descriptor
Apr 01, 2021 00:13:22.315 [6112] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 Rise of an Empire (2014) [1080p]\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4: Bad file descriptor
Apr 01, 2021 00:13:36.810 [6112] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\Inglourious.Basterds.2009.1080p.BluRay.x264.AC3-ETRG\Inglourious.Basterds.2009.1080p.BluRay.x264.AC3-ETRG.mp4: Bad file descriptor
Mar 31, 2021 23:09:36.887 [11488] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 (2006) [1080p]\300.2006.BluRay.1080p.x264.YIFY.mp4: Bad file descriptor
Mar 31, 2021 23:09:55.479 [13548] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 Rise of an Empire (2014) [1080p]\300.Rise.of.an.Empire.2014.1080p.BluRay.x264.YIFY.mp4: Bad file descriptor
Mar 31, 2021 23:10:11.956 [8560] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\Avatar\Avatar.ECE.2009.720p.BrRip.x264.bitloks.YIFY.mp4: Bad file descriptor
Mar 31, 2021 23:05:49.086 [5820] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 (2006) [1080p]\300.2006.BluRay.1080p.x264.YIFY.mp4: Bad file descriptor
Binary file Plex Media Server.3.log matches
Mar 31, 2021 14:17:29.232 [5924] ERROR - [Transcoder] P:\FILMES\PlexHD\FILMES\300 (2006) [1080p]\300.2006.BluRay.1080p.x264.YIFY.mp4: Bad file descriptor
Binary file Plex Media Server.4.log matches
