Error "Failed to convert '1970-01-01 00:59:01' to epoch."
Server Version#: 1.14.1.5488
Player Version#: 3.89.2
I’ve recently had some instability issued with my PMS, and after upgrading and checking pretty much everything else I’ve found that I’ve got a few things hammering my Plex log with errors.
First one is some issue with converting a timestamp to epoch. I’ve deleted quite a few media files that I found with “Date added” as 01.01.1970", but the problem persists. I’ve checked all my libraries and can’t find any timestamp that is 01.01.1970 anymore, so I dont know where to look.
Any ideas?
Mar 06, 2019 14:42:17.649 [0x149494bfd700] ERROR - [Time] Failed to convert '1970-01-01 00:59:01' to epoch.
Mar 06, 2019 14:42:17.650 [0x14959c3ff700] ERROR - [Time] Failed to convert '1970-01-01 00:59:01' to epoch.
Mar 06, 2019 14:42:17.651 [0x1495907ff700] ERROR - [Time] Failed to convert '1970-01-01 00:59:01' to epoch.
Mar 06, 2019 14:42:17.651 [0x14959c3ff700] ERROR - [Time] Failed to convert '1970-01-01 00:59:01' to epoch.
Mar 06, 2019 14:42:17.652 [0x14959c3ff700] ERROR - [Time] Failed to convert '1970-01-01 00:59:01' to epoch.
Mar 06, 2019 14:42:17.656 [0x1495907ff700] ERROR - [Time] Failed to convert '1970-01-01 00:59:01' to epoch.
I will need DEBUG mode logs. What you show here has it filtered or turned off.
Please recreate / re-capture, Settings - Server - Troubleshooting - Download Logs
Attach the ZIP
also please include distro and version information.
Thanks,
I’m running Unraid 6.6.7.
I seem to have solved the issues I was having by removing my Music library. I wasnt using it anyway, so it might have been for the better :slight_smile:
EDIT: Nope. Still seeing this issue.
Diagnostics attached
EDIT2: Diagnostics removed.
So just to follow up for anyone finding this after a search.
I removed all episodes/movies I found with date added/created/aired as 1970-01-01 but still saw this issue. Had to manually edit the database for the remaining items that were “added” 1970-01-01. Turned out to be a number of actual shows (not individual episodes) and connecting metadata.
EDIT: Also this had nothing to do with my instability issue afaik. That was caused by PlexKodiConnect creating tens of thousands of playlists…
