Server Version#:1.41.5.9522/Linux (Debian 12.5 Update)
Player Version#: 4.145.1
Hello,
I currently have a version of Plex on Linux Debian 12.5 updated to version 1.41.5.9522. This computer has been running Plex for two years, and the database was created natively using version 1.3x.
I have several problems with this Sqlite database (which by the way, its power leaves a lot to be desired with large databases like mine), specifically it seems that at some point (back in version 1.40.x) with the date data type (now it seems to be a unoc type, this causes that when I view any of my series libraries with the filter “All / TV Series / By date it was Added” the last series that I have added apparently appear correctly without any problem, but when I start through the library configuration “Recently added TV series” I get series with completely strange data, as if the date they were added was January 1, 1970, I consult the database (via SQLite) and the data that appears in added is December 13, 2023 … I think the startup module has some kind of bug that does not control that this date is of a different type UNOC and Therefore, it sets a non-random date of January 1, 1970.
I believe that in a version change, when making this change to the database, the corresponding adjustments were not made to the home display module.
Thanks in advance,
Alex
