Error in transcoding 4K files
Server Version#: Version 1.18.7.2457
Player Version#: same problem on Chrome web player 4.22.2 and LG Smart TV (webOS)
Plex running on a docker container in OMV 5.0
Hello board,
It seems like whenever I try to play most of my 4K files it fails and I get a transcoding error.
No problem with full HD content and a small minority of the other 4K files I have…
This is part of the log file in which I located the error:
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Selected protocol dash; container: mp4
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: analyzing media item 10181
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Avengers: Endgame (2019): Direct Play is disabled
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Avengers: Endgame (2019): media must be transcoded in order to use the dash protocol
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Avengers: Endgame (2019): no direct play video profile exists for http/mkv/hevc
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Avengers: Endgame (2019): no direct play video profile exists for http/mkv/hevc/eac3
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - Avengers: Endgame - video.height limitation applies: 2160 > 1280
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Avengers: Endgame (2019): no remuxable profile found, so video stream will be transcoded
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Cannot direct stream video stream due to profile or setting limitations
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - Scaled up video bitrate to 112846Kbps based on 4.500000x fudge factor.
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - Scaled maximum bitrate for resolution reduction to 39635Kbps.
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Cannot direct stream audio stream due to codec eac3 when profile only allows aac
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - MDE: Avengers: Endgame (2019): selected media 0 / 10181
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - Streaming Resource: Adding session 0x7fb41015e960:sg92ue6tm6d0kvwg9ltgjwvs which is using transcoder slot.  Used slots is now 1
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - Streaming Resource: Added session 0x7fb41015e960:sg92ue6tm6d0kvwg9ltgjwvs
Mar 02, 2020 10:02:07.920 [0x7fb483fff700] DEBUG - Streaming Resource: Reached Decision id=10611 codes=(General=1001,Direct play not available; Conversion OK. Direct Play=3000,App cannot direct play this item. Direct play is disabled. Transcode=1001,Direct play not available; Conversion OK.) media=(id=10181 part=(id=10204 decision=transcode container=mp4 protocol=dash streams=(Video=(id=11817 decision=transcode bitrate=39635 encoder=libx264 width=2276 height=1280) Audio=(id=11818 decision=transcode bitrate=256 encoder=aac channels=2 rate=48000))))
Mar 02, 2020 10:02:07.921 [0x7fb491bd3700] DEBUG - Completed: [192.168.178.29:54741] 200 GET /video/:/transcode/universal/decision?hasMDE=1&path=%2Flibrary%2Fmetadata%2F10611&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=3zp3z0gub7csngpz5w0mlavs&subtitles=burn&Accept-Language=en (7 live) GZIP 9ms 7010 bytes (pipelined: 5)
Mar 02, 2020 10:02:08.000 [0x7fb4913d2700] DEBUG - Auth: authenticated user 1 as massenzio23@gmail.com
Mar 02, 2020 10:02:08.000 [0x7fb4923d4700] DEBUG - Request: [192.168.178.29:54741 (Subnet)] GET /video/:/transcode/universal/start.mpd?hasMDE=1&path=%2Flibrary%2Fmetadata%2F10611&mediaIndex=0&partIndex=0&protocol=dash&fastSeek=1&directPlay=0&directStream=1&subtitleSize=100&audioBoost=100&location=lan&addDebugOverlay=0&autoAdjustQuality=0&directStreamAudio=1&mediaBufferSize=102400&session=3zp3z0gub7csngpz5w0mlavs&subtitles=burn&Accept-Language=en (7 live) GZIP Signed-in Token (massenzio23@gmail.com)
Mar 02, 2020 10:02:08.000 [0x7fb4923d4700] DEBUG - Found session GUID of 3zp3z0gub7csngpz5w0mlavs in session start.
Mar 02, 2020 10:02:08.000 [0x7fb4923d4700] DEBUG - TranscodeUniversalRequest: using augmented profile Web
Mar 02, 2020 10:02:08.000 [0x7fb4923d4700] DEBUG - Downloading document http://127.0.0.1:32400/library/metadata/10611?checkFiles=1&includeBandwidths=1&offset=-1&X-Plex-Incomplete-Segments=1&X-Plex-Session-Identifier=sg92ue6tm6d0kvwg9ltgjwvs
Mar 02, 2020 10:02:08.000 [0x7fb4923d4700] DEBUG - Auth: authenticated user 1 as massenzio23@gmail.com
Mar 02, 2020 10:02:08.008 [0x7fb4923d4700] DEBUG - It took 10.000000 ms to retrieve 172 items.
Mar 02, 2020 10:02:08.009 [0x7fb4923d4700] DEBUG - We're going to try to auto-select an audio stream for account 1.
Mar 02, 2020 10:02:08.009 [0x7fb4923d4700] DEBUG - Selecting best audio stream for part ID 10204 (autoselect: 1 language: it)
Mar 02, 2020 10:02:08.009 [0x7fb4923d4700] DEBUG - Audio Stream: 11818, Subtitle Stream: -1
Mar 02, 2020 10:02:08.011 [0x7fb4923d4700] DEBUG - Found session GUID of 3zp3z0gub7csngpz5w0mlavs in session start.
Mar 02, 2020 10:02:08.011 [0x7fb4923d4700] DEBUG - Cleaning directory for session 3zp3z0gub7csngpz5w0mlavs ()
Mar 02, 2020 10:02:08.011 [0x7fb4923d4700] DEBUG - Starting a transcode session 3zp3z0gub7csngpz5w0mlavs at offset -1.0 (state=3)
Mar 02, 2020 10:02:08.012 [0x7fb4923d4700] WARN - CodecManager: EAE exited with code 13. Restarting.
Mar 02, 2020 10:02:08.012 [0x7fb4923d4700] INFO - CodecManager: starting EAE at "/tmp/pms-e205a294-8fed-4d50-afda-705c0491325d/EasyAudioEncoder"
Mar 02, 2020 10:02:08.012 [0x7fb4923d4700] DEBUG - Job running: '/config/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-527-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder'
Mar 02, 2020 10:02:08.012 [0x7fb4923d4700] DEBUG - Jobs: Starting child process with pid 495
Mar 02, 2020 10:02:08.012 [0x7fb492bd5700] DEBUG - Jobs: '/config/Library/Application Support/Plex Media Server/Codecs/EasyAudioEncoder-527-linux-x86_64/EasyAudioEncoder/EasyAudioEncoder' exit code for process 495 is 13 (failure)
Mar 02, 2020 10:02:08.012 [0x7fb4923d4700] DEBUG - [Universal] Using local file path instead of URL: /movies/Avengers.Endgame.2019.INTERNAL.HDR.2160p.WEB.H265-DEFLATE/Avengers.Endgame.2019.INTERNAL.HDR.2160p.WEB.H265-DEFLATE.mkv
Mar 02, 2020 10:02:08.012 [0x7fb4923d4700] DEBUG - TPU: hardware transcoding: zero-copy support not present
Mar 02, 2020 10:02:08.013 [0x7fb4923d4700] DEBUG - Job running: EAE_ROOT='/tmp/pms-e205a294-8fed-4d50-afda-705c0491325d/EasyAudioEncoder' FFMPEG_EXTERNAL_LIBS='/config/Library/Application\ Support/Plex\ Media\ Server/Codecs/0bc617e-2965-linux-x86_64/' XDG_CACHE_HOME='/config/Library/Application Support/Plex Media Server/Cache' XDG_DATA_HOME='/usr/lib/plexmediaserver/Resources' X_PLEX_TOKEN='xxxxxxxxxxxxxxxxxxxx' '/usr/lib/plexmediaserver/Plex Transcoder' '-codec:0' 'hevc' '-codec:1' 'eac3_eae' '-eae_prefix:1' '3zp3z0gub7csngpz5w0mlavs_' '-analyzeduration' '20000000' '-probesize' '20000000' '-i' '/movies/Avengers.Endgame.2019.INTERNAL.HDR.2160p.WEB.H265-DEFLATE/Avengers.Endgame.2019.INTERNAL.HDR.2160p.WEB.H265-DEFLATE.mkv' '-filter_complex' '[0:0]scale=w=2276:h=1280[0];[0]format=pix_fmts=yuv420p|nv12[1]' '-filter_complex' '[0:1] aresample=async=1:ocl='\''stereo'\'':osr=48000[2]' '-map' '[1]' '-metadata:s:0' 'language=eng' '-codec:0' 'libx264' '-crf:0' '16' '-maxrate:0' '39635k' '-bufsize:0' '79270k' '-r:0' '23.975999999999999' '-preset:0' 'veryfast' '-x264opts:0' 'subme=2:me_range=4:rc_lookahead=10:me=hex:8x8dct=1' '-force_key_frames:0' 'expr:gte(t,0+n_forced*1)' '-map' '[2]' '-metadata:s:1' 'language=eng' '-codec:1' 'aac' '-b:1' '256k' '-f' 'dash' '-seg_duration' '1' '-init_seg_name' 'init-stream$RepresentationID$.m4s' '-media_seg_name' 'chunk-stream$RepresentationID$-$Number%05d$.m4s' '-window_size' '5' '-delete_removed' 'false' '-skip_to_segment' '1' '-time_delta' '0.0625' '-manifest_name' 'http://127.0.0.1:32400/video/:/transcode/session/3zp3z0gub7csngpz5w0mlavs/cc74093e-de6a-432a-92ce-f80cb14f7c03/manifest?X-Plex-Http-Pipeline=infinite' '-avoid_negative_ts' 'disabled' '-map_metadata' '-1' '-map_chapters' '-1' 'dash' '-start_at_zero' '-copyts' '-vsync' 'cfr' '-y' '-nostats' '-loglevel' 'quiet' '-loglevel_plex' 'error' '-progressurl' 'http://127.0.0.1:32400/video/:/transcode/session/3zp3z0gub7csngpz5w0mlavs/cc74093e-de6a-432a-92ce-f80cb14f7c03/progress'
Mar 02, 2020 10:02:08.013 [0x7fb4923d4700] DEBUG - Jobs: Starting child process with pid 496
Mar 02, 2020 10:02:08.016 [0x7fb44f7fe700] DEBUG - Request: [127.0.0.1:50562 (Loopback)] PUT /video/:/transcode/session/3zp3z0gub7csngpz5w0mlavs/cc74093e-de6a-432a-92ce-f80cb14f7c03/progress?status=startup (8 live) Signed-in Token (massenzio23@gmail.com) (range: bytes=0-)
Mar 02, 2020 10:02:08.016 [0x7fb4913d2700] DEBUG - Completed: [127.0.0.1:50562] 204 PUT /video/:/transcode/session/3zp3z0gub7csngpz5w0mlavs/cc74093e-de6a-432a-92ce-f80cb14f7c03/progress?status=startup (8 live) 0ms 203 bytes (pipelined: 1) (range: bytes=0-)
Mar 02, 2020 10:02:08.017 [0x7fb483fff700] ERROR - [Transcoder] Unrecognized option 'crf:0'.
Mar 02, 2020 10:02:08.017 [0x7fb44f7fe700] ERROR - [Transcoder] Error splitting the argument list: Option not found
Mar 02, 2020 10:02:08.017 [0x7fb492bd5700] DEBUG - Jobs: '/usr/lib/plexmediaserver/Plex Transcoder' exit code for process 496 is 1 (failure)
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Streaming Resource: Terminating session 0x7fb41015e960:sg92ue6tm6d0kvwg9ltgjwvs which is using transcoder slot.  Used slots is now 0
Mar 02, 2020 10:02:08.018 [0x7fb4923d4700] DEBUG - Using default transcode duration of 120 minutes
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Streaming Resource: Terminated session 0x7fb41015e960:sg92ue6tm6d0kvwg9ltgjwvs with reason Conversion failed. The transcoder exited due to an error.
Mar 02, 2020 10:02:08.018 [0x7fb4923d4700] DEBUG - Started session successfully: 3zp3z0gub7csngpz5w0mlavs
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Killing job.
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Signalling job ID 496 with 9
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Job was already killed, not killing again.
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Stopping transcode session 3zp3z0gub7csngpz5w0mlavs
Mar 02, 2020 10:02:08.018 [0x7fb490bd1700] DEBUG - Transcoder: Cleaning old transcode directories.
Do you have any idea on how to solve this?
Thanks in advance!
In short, don’t try and transcode 4K files.
Start here:
“Don’t try to transcode 4K files” was not the answer I was looking for, but thanks for the quick feedback.
Is it known the reason why some 4k files work and some don’t? is it a HEVC problem?
From the log I added, what is causing the issue? I thought it might be a folder permission problem…
What are my options now? Pay for the Plex Pass and direct stream? Not playing the files from Plex but using another player?
We would need more information in order to start dissecting what is going on. Specs of your server and XML examples from a working and non-working file.
But in reality, you really don’t want to be transcoding 4K files. There is a lot of good information in the thread I linked to, I highly recommend reading through it.
