Error issuing curl_easy_perform(handle): 7 flooding my logs
I keep seeing the error below in my logs. That device, .16, is a thermostat. Maybe at some point, there was something that connected to Plex, like my HDHR, but not anymore. How can I get rid of it? I deleted the HDHR device and added it again, but didn’t change anything.
May 05, 2020 13:24:38.649 [0x70000ce7d000] ERROR - Error issuing curl_easy_perform(handle): 7
May 05, 2020 13:24:38.649 [0x70000ce7d000] WARN - HTTP error requesting GET http://192.168.11.16:49153/gatedesc.xml (7, Couldn’t connect to server) (Failed to connect to 192.168.11.16 port 49153: Connection refused)
May 05, 2020 13:24:38.649 [0x70000ce7d000] ERROR - SSDP: Error parsing device schema for http://192.168.11.16:49153/gatedesc.xml
May 05, 2020 13:25:11.204 [0x70000ce7d000] ERROR - Error issuing curl_easy_perform(handle): 7
May 05, 2020 13:25:11.204 [0x70000ce7d000] WARN - HTTP error requesting GET http://192.168.11.16:49153/gatedesc.xml (7, Couldn’t connect to server) (Failed to connect to 192.168.11.16 port 49153: Connection refused)
May 05, 2020 13:25:11.204 [0x70000ce7d000] ERROR - SSDP: Error parsing device schema for http://192.168.11.16:49153/gatedesc.xml
May 05, 2020 13:25:41.208 [0x70000ce7d000] ERROR - Error issuing curl_easy_perform(handle): 7
May 05, 2020 13:25:41.208 [0x70000ce7d000] WARN - HTTP error requesting GET http://192.168.11.16:49153/gatedesc.xml (7, Couldn’t connect to server) (Failed to connect to 192.168.11.16 port 49153: Connection refused)
May 05, 2020 13:25:41.209 [0x70000ce7d000] ERROR - SSDP: Error parsing device schema for http://192.168.11.16:49153/gatedesc.xml
Server Version#:1.19.3.2740
Player Version#:4.32.2
I get the same thing. I run an iptv emulator on another machine and plex recognizes it as a HDHomeRun (Even though I don’t have live tv setup on plex).
I’m guessing for whatever reason plex sees your device as a potential tv source.
