Error loading Lyrics
For any songs, when clicking on Lyrics, I would get either an error (on Plex web or Plex windows app) or nothing (on Plexamp).
I am running Plex Version 1.32.7.7621 through Docker on Ubuntu 22.04.3 LTS
Looking at the logs it seems that the lyrics are retrieved but the parsing is failing:
Oct 31, 2023 14:53:43.191 [140505087478584] DEBUG - Request: [192.168.10.8:55730 (Allowed Network (WAN))] GET /library/streams/39809?format=xml&includeInlineAttribution=1&includeFields=thumbBlurHash (9 live) #64f37 TLS GZIP Signed-in Token (mattrosset) (Android)
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: Entity: line 4:
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: parser
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: error :
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: Attribute available_translations redefined
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: ilable_translations=“it” available_translations=“fr” available_translations=“es”
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: ^
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: Entity: line 7:
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] XML: Extra content at the end of the document
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] Error parsing content.
Oct 31, 2023 14:53:43.498 [140505087478584] ERROR - [Req#64f37/Req#64f3e] LyricFind: Error parsing returned lyrics - Error parsing file
Oct 31, 2023 14:53:43.499 [140505217284920] DEBUG - Completed: [192.168.10.8:55730] 404 GET /library/streams/39809?format=xml&includeInlineAttribution=1&includeFields=thumbBlurHash (9 live) #64f37 TLS GZIP 308ms 379 bytes (pipelined: 27)
Any idea what could be the issue or at least where to investigate next?
Regards,
I am also having the same issue it was just working 3 days ago. I’m annoyed. I tried looking everywhere for the solution. I even refreshed metadata. The only lyrics working is the ones I had to manually add to some songs but everything else isn’t working. I think it’s an issue with lyricsfind embedded into Plex. I also realized it real time lyrics not working I went to check the lyrics and it shows the lyrics but it’s not showing the real time one? Any solution to this? Thanks in advance.
We’re investigating, thanks for the report.
Am also having the same problem since applying the update today, running on QNAP NAS drive. Running version Version 1.32.7.7621. Just to be clear it was working today then I applied the update and it stopped working.
This should be resolved now, please let me know if you still have any issues and the exact track causing the problem.
Thanks it works!
