Error Message "A problem has been detected with a core component of Plex Media "
Server Version#:1.40.4.8840
It has asked me to provide logs.
Plex Media Server Logs_2025-12-06_13-14-39.zip (4.7 MB)
I see some network and metadata issues in your logs.
I would start by rebooting the modem/router and everything connected to it, including any wireless devices.
Then uninstall Plex using the first option (keep all files).
When reinstalling Plex, use the Plex token option, to make sure the server is claimed when reinstalling.
Use the latest version found on Plex Downloads
If you still have issues after that, then run ChuckPa’s DBRepair script and optimise the database using the automatic option.
DBRepair - ChuckPa
Instructions are shown on the page above.
Once that is done, I would recommend that you Refresh Metadata for all of your Libraries.
That will be a lengthy process, but stick with it, it should help get things running smoothly again.
