So I recently wanted to try Archlinux and running Plex on it. Everythings seems fine until I actually try to stream something in the browser. Then I get the mentioned error. It is just the browser though. Connecting with the Android App does work and everything streams nicely.
I am aware, that Archlinux is probably not officially supported, but if someone could at least tell me what this error means it would really help.
Hi! I have the same problem in opensuse. Did you found solution?
Same issue here, ubuntu 16.04. Will try upgrading the server and report back.
Nah, found out the reason - it works in firefox but not in opera (on linux) - opera doesn’t have the h264 video decoder iirc and that is probably the reason.
This was my problem … sort of. Default Firefox was giving this error. I moved over to Chrome, and life is good. Thanks for getting me in the right direction!
