Error starting PMS on QNAP after upgrading QPKG
@madhitz
May I please get a ZIP of your databases?
  1. com.plexapp.plugins.library.db
  2. com.plexapp.plugins.library.blobs.db
I’ll open a PM for you to attach the link to where I can download them
(dropbox or similar is probably
PM sent.
Got some info for you.
We don’t know why/how it happened.
We see duplicated rows in the DB where no duplicates are allowed / can exist.
Engineering has given me how to fix your DB ONLY
  1. Stop Plex
  2. SSH into the QNAP
  3. sudo bash
  4. whoami (confirm you are admin)
# Get into the Databases directory
cd /share/*/.qpkg/Ple*/Li*/Ple*/Plu*/Datab*
ls -la         # Confirms you are in Databases
# Start Plex SQLite
/share/*/.qpkg/Ple*/*SQLite* com.plexapp.plugins.library.db
Now we copy/paste these two commands (VERY LONG) into the sqlite> prompt
DELETE FROM schema_migrations WHERE version IN ( select version FROM( SELECT version, ROW_NUMBER() OVER(PARTITION BY version) AS rownum FROM schema_migrations) AS sub WHERE rownum > 1);
CREATE UNIQUE INDEX "unique_schema_migrations" ON "schema_migrations" ("version" );
When done, Control+D (eof) to exit gracefully from SQLite
Start PMS,
Confirm normal operation,
Now upgrade PMS.
I have a question for you.
Have you, at any time, used DBRepair and told it to IGNORE ?
Hi Chuck,
All steps performed as requested and PMS now starting and running latest production software correctly.
Thank you for all your help.
To answer the final question, I do not believe we’ve ever used DBRepair in the past with IGNORE option enabled. IF we did, it would have been a long time ago, as gladly the PMS software is generally very robust and only requires simple upgrades/updates.
Derek
Derek,
Thank you for confirming.
This confirms for us that it’s something PMS did. Now to find out why or how to remedy.
(Discussion is that DBRepair is about to become a WHOLE lot smarter about what should be INSIDE the DB tables)
That’s great. Always nice to know the little loopholes and bugs that exist – as you said, the challenges now are to figure them out. If I can help with anything else, including beta testing, access to library, or other samples of database states, let me know.
The best insight I can provide now is that possibly it was a hard shutdown of the NAS at some point maybe kicked this off? I know we did have a UPS fail which caused a hard down situation. I also know that one time the upgrade via the QNAP GUI barfed and that’s when I started manually doing it via a CLI. These are just speculative of course.
As mentioned previously, I have 2 almost identical setups (same QNAP model, same memory and drive configuration, same version of PMS, and basically the same library contents, only difference being audience/users) and neither one of them had this issue. I wish I had the logs to provide to you, as that may be of some insight, but I don’t believe they exist.
