Log files have been uploaded. Also uploaded screen shots of error received while attempting to select a channel from the Live TV guide. HDHOMERUN is fully functional from my HDHOMERUN app.
May 18, 2025 16:24:19.428 [140300734466872] WARN - [Req#3cd7c95/Grabber/5fc76c17c40548002d70ca09-5fc705ffc40548002d545a9d-q7opxvnma4pjyrydn4s43c22] Low disk space: 0B source file, 4MB capacity, 64.09MB available on "/plex.transcoding.tmp/Transcode/Sessions"
May 18, 2025 16:24:19.428 [140300734466872] WARN - [Req#3cd7c95/Grabber/5fc76c17c40548002d70ca09-5fc705ffc40548002d545a9d-q7opxvnma4pjyrydn4s43c22] TranscodeSession: inadequate disk space for transcode
May 18, 2025 16:24:19.428 [140300734466872] DEBUG - [Req#3cd7c95/Grabber/5fc76c17c40548002d70ca09-5fc705ffc40548002d545a9d-q7opxvnma4pjyrydn4s43c22] Streaming Resource: Terminated session 0x7f9a6c583698:17550c10-d72e-4fd8-9ad3-e03e0e81af46 with reason Not enough disk space to convert this item.
May 18, 2025 16:24:19.428 [140300734466872] ERROR - [Req#3cd7c95/Grabber/5fc76c17c40548002d70ca09-5fc705ffc40548002d545a9d-q7opxvnma4pjyrydn4s43c22] Failed to start session.
May 18, 2025 16:24:19.428 [140300734466872] ERROR - [Req#3cd7c95/Grabber/5fc76c17c40548002d70ca09-5fc705ffc40548002d545a9d-q7opxvnma4pjyrydn4s43c22] Recorder: Unable to create transcode session or session failed to start.
In general, we users are waiting on the FFMPEG upgrade to 6.1 to finish work that was done on the Live TV & DVR to add HEVC encoding. Right now it only does software decoding of the tuner stream which has put a spotlight on weak CPU’s in NAS’s and other devices. You also need to make sure that in each tuner setting you have “CONVERT VIDEO WHILE RECORDING” off.
For the new IOS and Android mobile clients, they don’t support mpeg2 so all streams need to be transcoded and coupled with the software decode it may be enough for failure.
