Error with named : "no valid signature found"
Server Version#: 4.74.2
Hello.
I contact you because I have a persistent error with my Plex server installed on a Debian 11.
In the syslog I have the following error:
  • Feb 15 13:49:26 ns332748 named[351451]: validating plex.tv/SOA: no valid signature found
  • Feb 15 13:49:26 ns332748 named[351451]: validating plex.tv/A: no valid signature found
  • Feb 15 13:49:26 ns332748 named[351451]: validating plex.tv/NSEC: no valid signature found
I searched on the internet how to solve this error, but I can’t find any answer to my problem.
Would you know how to solve this problem?
Thank you.
Best regards,
This isn’t related to your local Plex Media Server installation, at least not directly. I’m pretty sure this is your local DNS server complaining that plex.tv isn’t validating via DNSSEC.
So:
  • Are you running a local DNS server using BIND (named)?
  • Do you have it configured to always use DNSSEC validation (“dnssec-validation yes” in named.conf)?
Hello @pshanew
That’s also what I was thinking. For this also does not come from Plex.
To answer your questions /
  • Yes, I use BIND.
  • It is configured to use Cloudflare DNS. On my named.conf, dnssec-validation is auto.
I can pass dnssec-validation to yes to see if that solves my problem.
Setting this to “yes” is actually more strict, so I’m not sure if that will help; you can certainly try it though.
What is the problem you’re seeing? It may not even be related to this. You can obviously browse the forums, which are on a *.plex.tv host.
[Edit]
Also, what do you see when you run the following?
delv plex.tv A
delv plex.tv SOA
delv plex.tv NSEC
You can query different DNS servers in the same way as dig by including an @1.1.1.1, for example.
On my own system they all return the “no valid signature found” result.
With the delv commands, I have the same result as you.
  • validating plex.tv/A: no valid signature found
  • validating plex.tv/SOA: no valid signature found
  • validating plex.tv/NSEC: no valid signature found
With the dig commands, I did get a resolution using Cloudflare.
So everything is normal then. Anyway, thank you for taking the time to respond to my request.
I’m getting the same error in my system logs (/var/log/syslog)
System is Ubuntu 20.04.3 LTS
I am using BIND as DNS for the local network because I won’t tolerate adverts delivered via DNS.
Feb 17 14:05:28  named[894]: validating forums.plex.tv/CNAME: no valid signature found
Feb 17 14:05:46  named[894]: validating plex.tv/A: no valid signature found
Feb 17 14:05:48  named[894]: validating pubsub.plex.tv/CNAME: no valid signature found
This goes on whenever the plex process might need to access DNS. but there’s no need to spam this thread with it.
There are no similar warnings for other domains, so the problem is specific to the plex.tv domain.
As an experiment, I’ve put an end to the errors by disabling DNSSEC in the BIND config files and it does stop the errors.
This leads me to wonder if Plex itself has their DNS set up properly.
Running Ubuntu 20.04.3 LTS here and not seeing that.
I’m checking with operations anyway
How are you reproducing that with the command line and which DNS server IPs please ?
I checked with Operations.
Plex uses Cloudflare for the DNS but registration is with a different registrar for the DNSSEC.
They have moving the registrar on their radar.
It’s a renewal timing issue.
It will get all put together but not instantly
Hello @ChuckPa
I don’t know what command is used. However, I have seen in the Plex logs and on the same time slot, I have the following execution:
Feb 15, 2022 13:48:58.499 [0x7f613591ab38] DEBUG - Sync: uploadStatus
Feb 15, 2022 13:49:25.180 [0x7f613605eb38] DEBUG - Request: [54.170.120.91:54002 (WAN)] GET /identity (2 live) TLS Signed-in
Feb 15, 2022 13:49:25.181 [0x7f6136b63b38] DEBUG - Completed: [54.170.120.91:54002] 200 GET /identity (2 live) TLS 1ms 398 bytes (pipelined: 1)
Feb 15, 2022 13:49:26.185 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54059 (WAN)] GET /media/providers (3 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.196 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54059] 200 GET /media/providers (3 live) TLS GZIP 11ms 4949 bytes (pipelined: 1)
Feb 15, 2022 13:49:26.256 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54059 (WAN)] GET /status/sessions (3 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.256 [0x7f613605eb38] DEBUG - [Now] Adding 0 sessions.
Feb 15, 2022 13:49:26.258 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54059] 200 GET /status/sessions (3 live) TLS GZIP 2ms 475 bytes (pipelined: 2)
Feb 15, 2022 13:49:26.279 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54059 (WAN)] GET /:/prefs (5 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.303 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54059] 200 GET /:/prefs (6 live) TLS GZIP 24ms 9924 bytes (pipelined: 3)
Feb 15, 2022 13:49:26.305 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54062 (WAN)] GET /updater/status (6 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.307 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54062] 200 GET /updater/status (6 live) TLS GZIP 1ms 565 bytes (pipelined: 1)
Feb 15, 2022 13:49:26.323 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54064 (WAN)] GET /:/websockets/notifications (6 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.323 [0x7f613605eb38] DEBUG - WebSocket: Performing handshake from origin https://app.plex.tv
Feb 15, 2022 13:49:26.324 [0x7f613605eb38] DEBUG - Beginning read from WebSocket
Feb 15, 2022 13:49:26.332 [0x7f6136628b38] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Feb 15, 2022 13:49:26.332 [0x7f613591ab38] DEBUG - PublicAddressManager: Obtaining public IP.
Feb 15, 2022 13:49:26.332 [0x7f6136628b38] DEBUG - NAT: UPnP, attempting port mapping.
Feb 15, 2022 13:49:26.334 [0x7f613591ab38] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Feb 15, 2022 13:49:26.430 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54062 (WAN)] GET /photo/:/transcode?url=https%3A%2F%2Fplex.tv%2Fusers%2F5e14007d32■■■896%2Favatar%3Fc%3D1644929117%26size%3D80&w>
Feb 15, 2022 13:49:26.431 [0x7f613605eb38] DEBUG - Photo transcoder: Request for url [https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=80] (is local: 0 upscaled: 0)
Feb 15, 2022 13:49:26.450 [0x7f613605eb38] DEBUG - HTTP requesting GET https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=80
Feb 15, 2022 13:49:26.480 [0x7f613601ab38] DEBUG - Request: [XXX-XXX-XXX-XXX:54059 (WAN)] GET /photo/:/transcode?url=https%3A%2F%2Fplex.tv%2Fusers%2F5e14007d32■■■896%2Favatar%3Fc%3D1644929117%26size%3D120&>
Feb 15, 2022 13:49:26.481 [0x7f613601ab38] DEBUG - Photo transcoder: Request for url [https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=120] (is local: 0 upscaled: 0)
Feb 15, 2022 13:49:26.483 [0x7f613601ab38] DEBUG - HTTP requesting GET https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=120
Feb 15, 2022 13:49:26.506 [0x7f6135ed6b38] DEBUG - Request: [XXX-XXX-XXX-XXX:54063 (WAN)] OPTIONS /updater/check?download=0 (6 live) TLS GZIP Signed-in Token ()
Feb 15, 2022 13:49:26.507 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54063] 200 OPTIONS /updater/check?download=0 (6 live) TLS GZIP 0ms 376 bytes (pipelined: 1)
Feb 15, 2022 13:49:26.534 [0x7f6135ed6b38] DEBUG - Request: [XXX-XXX-XXX-XXX:54063 (WAN)] GET /activities (6 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.537 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54063] 200 GET /activities (6 live) TLS GZIP 2ms 475 bytes (pipelined: 2)
Feb 15, 2022 13:49:26.544 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.2s) 200 response from GET http://plex.tv/pms/:/ip
Feb 15, 2022 13:49:26.545 [0x7f613591ab38] DEBUG - PublicAddressManager: Got public IP from http://plex.tv: 37.187.124.143
Feb 15, 2022 13:49:26.557 [0x7f6135ed6b38] DEBUG - Request: [XXX-XXX-XXX-XXX:54063 (WAN)] PUT /updater/check?download=0 (8 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:26.557 [0x7f6135ed6b38] DEBUG - AutoUpdate: requesting check endpoint: /updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.25.5.5492-12f6b8c83, >
Feb 15, 2022 13:49:26.557 [0x7f6135ed6b38] DEBUG - Downloading document https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.25.5.5492-12f6b8c83
Feb 15, 2022 13:49:26.558 [0x7f6135ed6b38] DEBUG - HTTP requesting GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.25.5.5492-12f6b8c83
Feb 15, 2022 13:49:26.629 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.1s) 200 response from GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&vers>
Feb 15, 2022 13:49:26.630 [0x7f6135ed6b38] INFO - AutoUpdate: no updates available
Feb 15, 2022 13:49:26.631 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54063] 200 PUT /updater/check?download=0 (8 live) TLS GZIP 74ms 320 bytes (pipelined: 3)
Feb 15, 2022 13:49:26.698 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.2s) 200 response from GET https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=120
Feb 15, 2022 13:49:26.699 [0x7f613601ab38] DEBUG - Photo cache obtained 18550 bytes from https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=120
Feb 15, 2022 13:49:26.699 [0x7f613601ab38] DEBUG - Saving original media file to /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/4b/4b03d12d946a2bb3216532a8>
Feb 15, 2022 13:49:26.714 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.3s) 200 response from GET https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=80
Feb 15, 2022 13:49:26.714 [0x7f613605eb38] DEBUG - Photo cache obtained 18550 bytes from https://plex.tv/users/5e14007d32■■■896/avatar?c=1644929117&size=80
Feb 15, 2022 13:49:26.714 [0x7f613605eb38] DEBUG - Saving original media file to /var/lib/plexmediaserver/Library/Application Support/Plex Media Server/Cache/PhotoTranscoder/2a/2a8f67c3347d98b61890c734>
Feb 15, 2022 13:49:26.718 [0x7f613601ab38] DEBUG - Created thumbnail of size 120x120, has pixels: 1
Feb 15, 2022 13:49:26.728 [0x7f613605eb38] DEBUG - Created thumbnail of size 80x80, has pixels: 1
Feb 15, 2022 13:49:26.734 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54062] 200 GET /photo/:/transcode?url=https%3A%2F%2Fplex.tv%2Fusers%2F5e14007d32■■■896%2Favatar%3Fc%3D1644929117%26size%3D80&w>
Feb 15, 2022 13:49:26.897 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54059] 200 GET /photo/:/transcode?url=https%3A%2F%2Fplex.tv%2Fusers%2F5e14007d32■■■896%2Favatar%3Fc%3D1644929117%26size%3D120&>
Feb 15, 2022 13:49:28.318 [0x7f6136b86b38] DEBUG - WebSocket: client initiated close
Feb 15, 2022 13:49:28.318 [0x7f6136b63b38] DEBUG - NotificationStream: Removing because of close
Feb 15, 2022 13:49:28.385 [0x7f6136b86b38] DEBUG - handleStreamRead code 1: stream truncated
Feb 15, 2022 13:49:28.385 [0x7f6136b86b38] DEBUG - Completed after connection close: [XXX-XXX-XXX-XXX:54064] -3 GET /:/websockets/notifications (8 live) TLS GZIP 2062ms 136 bytes
Feb 15, 2022 13:49:28.661 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54059 (WAN)] GET /media/providers (7 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:28.674 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54059] 200 GET /media/providers (7 live) TLS GZIP 13ms 4949 bytes (pipelined: 5)
Feb 15, 2022 13:49:28.930 [0x7f6135ed6b38] DEBUG - Request: [XXX-XXX-XXX-XXX:54059 (WAN)] GET /status/sessions (7 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:28.931 [0x7f6135ed6b38] DEBUG - [Now] Adding 0 sessions.
Feb 15, 2022 13:49:28.933 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54059] 200 GET /status/sessions (7 live) TLS GZIP 2ms 475 bytes (pipelined: 6)
Feb 15, 2022 13:49:28.937 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54062 (WAN)] GET /:/prefs (7 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:28.942 [0x7f613601ab38] DEBUG - Request: [XXX-XXX-XXX-XXX:54063 (WAN)] GET /updater/status (7 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:28.944 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54063] 200 GET /updater/status (7 live) TLS GZIP 2ms 565 bytes (pipelined: 4)
Feb 15, 2022 13:49:28.959 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54062] 200 GET /:/prefs (8 live) TLS GZIP 22ms 9924 bytes (pipelined: 3)
Feb 15, 2022 13:49:28.979 [0x7f6135ed6b38] DEBUG - Request: [XXX-XXX-XXX-XXX:54068 (WAN)] GET /:/websockets/notifications (8 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:28.980 [0x7f6135ed6b38] DEBUG - WebSocket: Performing handshake from origin https://app.plex.tv
Feb 15, 2022 13:49:28.980 [0x7f6135ed6b38] DEBUG - Beginning read from WebSocket
Feb 15, 2022 13:49:29.078 [0x7f613601ab38] DEBUG - Request: [XXX-XXX-XXX-XXX:54062 (WAN)] GET /activities (8 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:29.080 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54062] 200 GET /activities (8 live) TLS GZIP 2ms 475 bytes (pipelined: 4)
Feb 15, 2022 13:49:29.147 [0x7f613605eb38] DEBUG - Request: [XXX-XXX-XXX-XXX:54062 (WAN)] PUT /updater/check?download=0 (8 live) TLS GZIP Signed-in Token (Plex-administrateur)
Feb 15, 2022 13:49:29.148 [0x7f613605eb38] DEBUG - AutoUpdate: requesting check endpoint: /updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.25.5.5492-12f6b8c83, >
Feb 15, 2022 13:49:29.148 [0x7f613605eb38] DEBUG - Downloading document https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.25.5.5492-12f6b8c83
Feb 15, 2022 13:49:29.148 [0x7f613605eb38] DEBUG - HTTP requesting GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&version=1.25.5.5492-12f6b8c83
Feb 15, 2022 13:49:29.179 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.0s) 200 response from GET https://plex.tv/updater/products/5/check.xml?build=linux-x86_64&channel=16&distribution=debian&vers>
Feb 15, 2022 13:49:29.180 [0x7f613605eb38] INFO - AutoUpdate: no updates available
Feb 15, 2022 13:49:29.181 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:54062] 200 PUT /updater/check?download=0 (8 live) TLS GZIP 34ms 320 bytes (pipelined: 5)
Feb 15, 2022 13:49:29.337 [0x7f6136628b38] DEBUG - NAT: UPnP, didn't find usable IGD.
Feb 15, 2022 13:49:29.337 [0x7f6136628b38] DEBUG - NAT: PMP, attempting mapping.
Feb 15, 2022 13:49:29.548 [0x7f613591ab38] DEBUG - NAT: UPnP, getPublicIP didn't find usable IGD.
Feb 15, 2022 13:49:29.549 [0x7f613591ab38] DEBUG - NAT: PMP::getPublicIP, couldn't send request for public IP
Feb 15, 2022 13:49:29.549 [0x7f613591ab38] DEBUG - HTTP requesting GET https://XXX-XXX-XXX-XXX.c89dabd58ef64e0b844e60df49d5939b.plex.direct:32400/identity
Feb 15, 2022 13:49:29.587 [0x7f6136628b38] WARN - NAT: PMP, got an error: Send Error.
Feb 15, 2022 13:49:29.588 [0x7f6136628b38] DEBUG - NAT: UPnP, attempting port mapping.
Feb 15, 2022 13:49:29.607 [0x7f6135ed6b38] DEBUG - Request: [XXX-XXX-XXX-XXX:40714 (Subnet)] GET /identity (9 live) TLS GZIP Signed-in
Feb 15, 2022 13:49:29.655 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/1.1 (0.1s) 200 response from GET https://XXX-XXX-XXX-XXX.c89dabd58ef64e0b844e60df49d5939b.plex.direct:32400/identity
Feb 15, 2022 13:49:29.656 [0x7f6136b63b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:40714] 200 GET /identity (9 live) TLS GZIP 48ms 480 bytes (pipelined: 1)
Feb 15, 2022 13:49:29.656 [0x7f613591ab38] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 15, 2022 13:49:29.658 [0x7f613591ab38] DEBUG - MyPlex: Last published value didn't change, we're done.
Feb 15, 2022 13:49:31.631 [0x7f613633db38] DEBUG - Checking if time for scheduled update
Feb 15, 2022 13:49:32.589 [0x7f6136628b38] DEBUG - NAT: UPnP, didn't find usable IGD.
Feb 15, 2022 13:49:32.589 [0x7f6136628b38] DEBUG - PublicAddressManager: Mapping failed.
Feb 15, 2022 13:49:32.590 [0x7f6136628b38] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 15, 2022 13:49:32.591 [0x7f6136628b38] DEBUG - MyPlex: Last published value didn't change, we're done.
I am watching another time slot on the same day.
  • Feb 15 00:49:27 ns332748 named[520]: validating plex.tv/SOA: no valid signature found
  • Feb 15 00:49:27 ns332748 named[520]: validating plex.tv/A: no valid signature found
  • Feb 15 00:49:27 ns332748 named[520]: validating plex.tv/NSEC: no valid signature found
Feb 15, 2022 00:48:58.480 [0x7f6136628b38] DEBUG - Sync: uploadStatus
Feb 15, 2022 00:49:26.297 [0x7f613633ab38] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Feb 15, 2022 00:49:26.305 [0x7f61360e9b38] DEBUG - NAT: UPnP, attempting port mapping.
Feb 15, 2022 00:49:26.311 [0x7f6136628b38] DEBUG - PublicAddressManager: Obtaining public IP.
Feb 15, 2022 00:49:26.383 [0x7f6136628b38] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Feb 15, 2022 00:49:26.845 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.5s) 200 response from GET http://plex.tv/pms/:/ip
Feb 15, 2022 00:49:26.854 [0x7f6136628b38] DEBUG - PublicAddressManager: Got public IP from http://plex.tv: XXX-XXX-XXX-XXX
Feb 15, 2022 00:49:29.330 [0x7f61360e9b38] DEBUG - NAT: UPnP, didn't find usable IGD.
Feb 15, 2022 00:49:29.330 [0x7f61360e9b38] DEBUG - NAT: PMP, attempting mapping.
Feb 15, 2022 00:49:29.581 [0x7f61360e9b38] WARN - NAT: PMP, got an error: Send Error.
Feb 15, 2022 00:49:29.581 [0x7f61360e9b38] DEBUG - NAT: UPnP, attempting port mapping.
Feb 15, 2022 00:49:29.857 [0x7f6136628b38] DEBUG - NAT: UPnP, getPublicIP didn't find usable IGD.
Feb 15, 2022 00:49:29.858 [0x7f6136628b38] DEBUG - NAT: PMP::getPublicIP, couldn't send request for public IP
Feb 15, 2022 00:49:29.859 [0x7f6136628b38] DEBUG - HTTP requesting GET https://XXX-XXX-XXX-XXX.c89dabd58ef64e0b844e60df49d5939b.plex.direct:32400/identity
Feb 15, 2022 00:49:29.912 [0x7f613599fb38] DEBUG - Request: [XXX-XXX-XXX-XXX:37184 (Subnet)] GET /identity (2 live) TLS GZIP Signed-in
Feb 15, 2022 00:49:29.954 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/1.1 (0.1s) 200 response from GET https://XXX-XXX-XXX-XXX.c89dabd58ef64e0b844e60df49d5939b.plex.direct:32400/identity
Feb 15, 2022 00:49:29.954 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:37184] 200 GET /identity (2 live) TLS GZIP 43ms 480 bytes (pipelined: 1)
Feb 15, 2022 00:49:29.964 [0x7f6136628b38] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 15, 2022 00:49:29.965 [0x7f6136628b38] DEBUG - MyPlex: Last published value didn't change, we're done.
Feb 15, 2022 00:49:31.180 [0x7f6136628b38] DEBUG - Checking if time for scheduled update
Feb 15, 2022 00:49:32.585 [0x7f61360e9b38] DEBUG - NAT: UPnP, didn't find usable IGD.
Feb 15, 2022 00:49:32.585 [0x7f61360e9b38] DEBUG - PublicAddressManager: Mapping failed.
Feb 15, 2022 00:49:32.586 [0x7f61360e9b38] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 15, 2022 00:49:32.587 [0x7f61360e9b38] DEBUG - MyPlex: Last published value didn't change, we're done.
  • Feb 18 00:49:26 ns332748 Plex Media Server[552]: sendto: Operation not permitted
  • Feb 18 00:49:29 ns332748 Plex Media Server[552]: sendto: Operation not permitted
Feb 18, 2022 00:48:58.603 [0x7f613632ab38] DEBUG - Sync: uploadStatus
Feb 18, 2022 00:49:26.590 [0x7f6135cb8b38] DEBUG - PublicAddressManager: Obtaining public address and mapping port.
Feb 18, 2022 00:49:26.598 [0x7f61360e9b38] DEBUG - NAT: UPnP, attempting port mapping.
Feb 18, 2022 00:49:26.605 [0x7f613632ab38] DEBUG - PublicAddressManager: Obtaining public IP.
Feb 18, 2022 00:49:26.606 [0x7f613632ab38] DEBUG - HTTP requesting GET http://plex.tv/pms/:/ip
Feb 18, 2022 00:49:26.858 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/2.0 (0.3s) 200 response from GET http://plex.tv/pms/:/ip
Feb 18, 2022 00:49:26.859 [0x7f613632ab38] DEBUG - PublicAddressManager: Got public IP from http://plex.tv: XXX-XXX-XXX-XXX
Feb 18, 2022 00:49:29.624 [0x7f61360e9b38] DEBUG - NAT: UPnP, didn't find usable IGD.
Feb 18, 2022 00:49:29.624 [0x7f61360e9b38] DEBUG - NAT: PMP, attempting mapping.
Feb 18, 2022 00:49:29.861 [0x7f613632ab38] DEBUG - NAT: UPnP, getPublicIP didn't find usable IGD.
Feb 18, 2022 00:49:29.861 [0x7f613632ab38] DEBUG - NAT: PMP::getPublicIP, couldn't send request for public IP
Feb 18, 2022 00:49:29.863 [0x7f613632ab38] DEBUG - HTTP requesting GET https://XXX-XXX-XXX-XXX.c89dabd58ef64e0b844e60df49d5939b.plex.direct:32400/identity
Feb 18, 2022 00:49:29.875 [0x7f61360e9b38] WARN - NAT: PMP, got an error: Send Error.
Feb 18, 2022 00:49:29.875 [0x7f61360e9b38] DEBUG - NAT: UPnP, attempting port mapping.
Feb 18, 2022 00:49:29.916 [0x7f613582db38] DEBUG - Request: [XXX-XXX-XXX-XXX:60260 (Subnet)] GET /identity (2 live) TLS GZIP Signed-in
Feb 18, 2022 00:49:29.967 [0x7f613686bb38] DEBUG - [HttpClient] HTTP/1.1 (0.1s) 200 response from GET https://XXX-XXX-XXX-XXX.c89dabd58ef64e0b844e60df49d5939b.plex.direct:32400/identity
Feb 18, 2022 00:49:29.968 [0x7f6136b86b38] DEBUG - Completed: [XXX-XXX-XXX-XXX:60260] 200 GET /identity (2 live) TLS GZIP 51ms 480 bytes (pipelined: 1)
Feb 18, 2022 00:49:29.968 [0x7f613632ab38] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 18, 2022 00:49:29.970 [0x7f613632ab38] DEBUG - MyPlex: Last published value didn't change, we're done.
Feb 18, 2022 00:49:32.881 [0x7f61360e9b38] DEBUG - NAT: UPnP, didn't find usable IGD.
Feb 18, 2022 00:49:32.881 [0x7f61360e9b38] DEBUG - PublicAddressManager: Mapping failed.
Feb 18, 2022 00:49:32.882 [0x7f61360e9b38] DEBUG - MyPlex: mapping state set to 'Mapped - Not Published'.
Feb 18, 2022 00:49:32.883 [0x7f61360e9b38] DEBUG - MyPlex: Last published value didn't change, we're done.
Feb 18, 2022 00:49:35.373 [0x7f613632ab38] WARN - NetworkServiceBrowser: Error sending out discover packet from XXX-XXX-XXX-XXX to 239.255.255.250: Operation not permitted
Feb 18, 2022 00:49:42.188 [0x7f6135cb8b38] DEBUG - Checking if time for scheduled update
I hope this will help you and answer your questions.
Best regards,
That snippet is copied/pasted from the system log /var/log/syslog. Many processes on a Linux system dump errors and such there.
You can follow it in real time by logging into the machine and typing " tail -f /var/log/syslog", which will show you the file as it’s being written. This is for Ubuntu 20.04.3 LTS; other distros may vary. You may also need root privileges depending upon the permissions on the file.
As far as which DNS servers, I operate my own DNS server on that machine. Most ISP DNS servers and the freebies use the DNS protocol to deliver advertising. If you fat finger a URL, you should get page/site not found, but instead you get a list of “search suggestions” which are really paid advertising. I will not put up with that. So about 10 years ago, I set up BIND on my Linux router/firewall/etc. machine to avoid it. This is not a forwarding setup, it’s a fully functional DNS server, configured to listen to requests on the inside interface only (my network)
All machines on the inside network use this machine for DNS. Therefore, any time any machine on the local network needs a plex.tv IP address, even for just a web browser, it will generate those errors.
You can test using delv; it works a lot like dig. For example:
delv @1.1.1.1 plex.tv SOA
You can specific different record types: A, NSEC, SOA, etc…
It seems to have full conntrack table, if u see:
nf_conntrack: table full, dropping packet
in your /var/log/kern.log
You can check that with:
cat /proc/sys/net/netfilter/nf_conntrack_count
to see current count
and with
cat /proc/sys/net/netfilter/nf_conntrack_max
you can check max value.
If that is your case, you can increase larger value for nf_conntrack for example:
echo 524277 > /proc/sys/net/netfilter/nf_conntrack_max
and you must make that on your /etc/sysctl.conf file by adding:
net.netfilter.nf_conntrack_max = 524277
Hello @PVasileff
Thanks for your feedback.
I looked at the nf_conntrack_max value, this one is at 65536.
The nf_conntrack_count value is 72.
So, for the moment, I leave the current parameters.
I’m keeping this on watch.
If you want to disable DNSSEC validation, you can do that in named.conf with adding:
    dnssec-enable no;
    dnssec-validation no;
    dnssec-lookaside no;
in
options {
section on your bind and restart it.
