"Exception caught determining whether we could skip" during scan
Server Version#: 1.25.5.5492-12f7b8c83
Overall scanning it working on the NAS except for a folder which contains all Movies. The error is below verbatim and from my understanding the ‘’ should be the name of the folder causing the issue? But it’s blank as you can see. Previously, this folder was successfully scanned (hundreds of files).
Exception caught determining whether we could skip ‘’ ~ The complexity of matching the regular expression exceeded predefined bounds. Try refactoring the regular expression to make each choice made by the state machine unambiguous. This exception is thrown to prevent “eternal” matches that take an indefinite period time to locate.
Exception caught scanning directory: [/Volumes/Media/Movies] (The complexity of matching the regular expression exceeded predefined bounds. Try refactoring the regular expression to make each choice made by the state machine unambiguous. This exception is thrown to prevent “eternal” matches that take an indefinite period time to locate.)
Interestingly enough the Plex Movie Legacy scanner works.
