Exclude Libraries from Search
I would love to have the ability to exclude libraries from my search bar. For example I have a Movies Library, Tv Shows Library, and a Study Material Library. I don’t want my study Materials Library to show up when i’m searching for a movie to watch.
Hi Khaswi,
This is very simple to do when you access your plex you have the full menu on the left side, here you will find a menu called “More” on the bottom of this if you press that one you can see the pin symbol and by pressing that you can either detach or attach it.
I hope this helps you out with your issue, otherwise, let me know and I will try and assist you.
