Excluding *New* Content with .plexignore?
from the help file:
Excluding New Content with .plexignore
I have several folders which I put in a .plexignore (as a hidden file on *nix based PMS and with hidden attribute on windows ntfs file system PMS).
The content of the .plexignore is either *.* or just *, because I did not figure out how it would ignore ALL files and (sub)folders inside the folder, containing the .plexignore file.
Plex seems to ignore the .plexignore file or its contents.
2½ Questions:
  1. When I want to ignore everything inside a folder, what do I have to put inside the .plexignore?
    *.* or * or something else?
  2. How do I ignore everything inside a folder, which has been already scanned into a library by plex?
Thank you!
It’s been some time since I played with .plexignore files… so I might be slightly off.
regarding #1:
# ignore all content of all subfolders
# ignore all content of that folder
# ignores a subfolder called "new-stuff"
new-stuff/*
Regarding #2:
You cannot do that as plexignore-rules apply to all content of a folder – Plex doesn’t distinguish by when a file has been added or if it has already been scanned before.
Not sure I fully get your question… once a file has been scanned, Plex will not add another record when it re-scans the folder (if that’s what your question is aiming at)
Thank you very much, I will test your suggestions and will come back with the result.
To clarify #2:
I was wondering, if already indexed files/folders will be removed from a library, when I add a .plexignore after plex has already indexed that files/folders.
Example:
Plex has scanned and indexed:
/folder/music1/files…
/folder/music2/files…
/folder/music3/files…
Now I put a .plexignore into
/folder/music2/
what will happen to the indexed files/folders when I rescan the library?
Will they be removed from the index or stay?
I expect they’ll removed, like
but my tests proved me wrong (but that was with maybe wrong content of .plexignore, so I will test again).
If you tell Plex to ignore those folders, it will no longer find the already indexed content. Therefore Plex should remove the files or at least flag them as “unavailable”
@tom80H
actually, when reading your post (regarding #1) again,
I see, I have to enter those 2 lines
into the .plexignore.
First line * for ignoring the folder itself, containing the .plexignore
and
second line */* for ignoring the folders subfolders.
That way, ALL content of this folder will be ignored.
Man, I really wish, the documentation would have had examples for my usecase…
What do you want to exclude?
You described a use case to ignore the entire content of a folder and its subfolders… so that’s what we went for.
Exactly what you’ve describe below.
…it took me some time to realize that 2 lines are nescessary to accomplish a simple “ignore all”. :slight_smile:
You could put the .plexignore file one level up and have a one-line statement like
folder-to-be-excluded/*
