Hi. I haven’t used this feature in a while so not sure what’s going on. I did make sure that the file is properly set up (ie “.plexignore” as the file name.
I have nothing actually in the file but it is placed at the root of the folder I want to exclude. Anyone else using this and works for you?
Yep…
File name…
When scanning in new content for your libraries, you can tell the scanner to ignore files or patterns by adding a .plexignore file to any folder in your Library’s content location. “.plexignore” is the exact name of the file to use; nothing more and nothing less (e.g. it does not have a separate file extension).
Root folder…
If you add the “.plexignore” file to the root (top-level) folder in the content location, the ignore rules will apply to all sub-folders.
What it does fail to mention…
Adding “*” to the file will exclude the folder
I figured I’d give that a try as a wildcard filter but really the guide should just mention that
@andy_d0 said:
Yep…
File name…
Root folder…
and below that it reads
Add one pattern per line for things you'd like to ignore
which means the .plexignore file can not be empty
