Hi All,
I have faced with an major issue via starting Plex Server on RPI model B.
Plex server is installed according an article:
Packages were installed without any errors.
But I could not start the server:
● plexmediaserver.service - Plex Media Server for Linux
Loaded: loaded (/lib/systemd/system/plexmediaserver.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Wed 2018-01-03 11:54:26 UTC; 1min 41s ago
Process: 393 ExecStart=/bin/sh -c LD_LIBRARY_PATH=/usr/lib/plexmediaserver “/usr/lib/plexmediaserver/Plex Media Server” (code=exited, status=132)
Process: 387 ExecStartPre=/bin/sh -c /usr/bin/test -d "{PLEX_MEDIA_SERVER_APPLICATION_SUPPORT_DIR}" || /bin/mkdir -p "{PLEX_MEDIA_SERVER_APPLICATION_SUPP
Main PID: 393 (code=exited, status=132)
Jan 03 11:54:21 raspberrypi systemd[1]: Starting Plex Media Server for Linux…
Jan 03 11:54:21 raspberrypi systemd[1]: Started Plex Media Server for Linux.
Jan 03 11:54:26 raspberrypi sh[393]: Illegal instruction
Jan 03 11:54:26 raspberrypi systemd[1]: plexmediaserver.service: Main process exited, code=exited, status=132/n/a
Jan 03 11:54:26 raspberrypi systemd[1]: plexmediaserver.service: Unit entered failed state.
Jan 03 11:54:26 raspberrypi systemd[1]: plexmediaserver.service: Failed with result ‘exit-code’.
In this case I could not collect server logs, but I collected the trace of the start.sh script. Please see it in attach.
cpu info:
processor : 0
model name : ARMv6-compatible processor rev 7 (v6l)
BogoMIPS : 697.95
Features : half thumb fastmult vfp edsp java tls
CPU implementer : 0x41
CPU architecture: 7
CPU variant : 0x0
CPU part : 0xb76
CPU revision : 7
Hardware : BCM2835
Revision : 000f
Serial : 000000009bc9adf7
OS version:
Linux raspberrypi 4.9.59+ #1047 Sun Oct 29 11:47:10 GMT 2017 armv6l GNU/Linux
Plex Packages:
plexmediaserver 0.9.16.4.1911-ee6e505-2~jessie all Dummy package for Plex Media Server for Linux plexmediaserver-installer 1.10.1.4602-f54242b6b-1
Cheers,
Pavel
