I’ve been trying out the new 2.0 and for the most part it seems really good. One thing that I am really missing from the old version is the ability to ‘back out’ of the application. If you kept pressing back on the remote eventually you would have been asked if you wanted to exit PMP. With the new version I have to navigate over to the user settings and exit that way. Is this something that can be modified?
Agreed… exit is in the worst possible place. Should be as you described.
This has been reported, and they’re working on it.
