ExoPlayer often unable to play on Android
Server Version#: 1.41.3.9314
Player Version#: 10.25.0.2403
I’ve been having issues with ExoPlayer for about the 6-8 weeks where it will just refuse to play content - whether streaming or downloaded. I tried disabling support for certain codecs, and looking for such errors in logs, but they did not work. I then tried an external player (VLC) and that worked for the most part. I then opted into the beta program on Android, hoping that there would be some fixes on ExoPlayer. Unfortunately, still no dice, and as of yesterday, VLC stopped working as well.
I took logs from the Android App from point where I interacted with Plex to resume playing are here: https://pastebin.com/dtpRG5sJ (alt: https://pastecode.io/s/9npqxt70)
(I redacted IPs and any identifiers I could find)
There are two issues I see in logs:
  • A java stack trace which says either invalid version or empty text.
  • Another stack trace which says it gets a 404 when trying to load the content.
To help debug the second item, I tried loading the same content on the Web App (4.143.0) on a laptop on the same network, and the content loaded with no issues.
Any help appreciated. I’m happy to try different configs or builds to debug.
