Failed Dependencies - PMS CentOS 7.6
Server Version#: Version 1.14.1.5488
$ sudo rpm -Uvh plexmediaserver-1.15.1.710-ece95b3a1.x86_64.rpm
warning: plexmediaserver-1.15.1.710-ece95b3a1.x86_64.rpm: Header V4 RSA/SHA1 Signature, key ID 3adca79d: NOKEY
error: Failed dependencies:
libxslt.so.1()(64bit) is needed by (installed) xmlsec1-1.2.20-7.el7_4.x86_64
libxslt.so.1()(64bit) is needed by (installed) xmlsec1-openssl-1.2.20-7.el7_4.x86_64
libxslt.so.1()(64bit) is needed by (installed) open-vm-tools-10.2.5-3.el7.x86_64
libxslt.so.1(LIBXML2_1.0.11)(64bit) is needed by (installed) xmlsec1-1.2.20-7.el7_4.x86_64
libxslt.so.1(LIBXML2_1.0.22)(64bit) is needed by (installed) xmlsec1-1.2.20-7.el7_4.x86_64
I had this same issue with an earlier 1.15 version but figured it was isolated and didn’t look into it. Now I need to get this resolved so I can get updated again. I haven’t had issues with this until 1.15. All updates until now were just fine. I tried searching for a relevant article but none seemed to fit my situation. Help would be greatly appreciated.
VMWare based VM that is single purpose. No other specific services running on the VM.
CentOS 7.6
2 Cores
4GB RAM
The original %spec had Autoprov enabled. This confused yum.
This is now resolved.
To clean up
yum clean all
yum autoremove plexmediaserver
Sweet. Resolved!
Thank you very much.
Won’t this uninstall plexmediaserver?
It removes the binary package.
It doesn’t remove your metadata.
It allows the errant dependencies to be properly cleaned up
Thank you, that worked. After removing and then installing the latest version of plexmediaserver, everything seems to be working.
