Updating with “rpm -Uvh plexmediaserver-1.15.0.659-9311f93fd.x86_64.rpm”, I see this:
error: Failed dependencies:
libjemalloc.so.1()(64bit) is needed by (installed) redis-3.2.12-2.el7.x86_64
Just me?
Just me?
Tag post with server-linux so proper folks will see it.
Done, thanks.
I think it’s just you. Something pulled in redis, or you installed it on your own. it’s deps are broke.
That is definitely not a PMS error.
I have correct the deps.
Autoprov: 0
Provides: config(plexmediaserver) plexmediaserver
Many thanks. Gloppie was correct, I removed redis and the rpm update applied OK.
