Fanart possible?
How important is the movie name? 98% of the times the name of the movie appears on the coverart? Just a thought …
And the other 2%? :D
You can actually just about fit in one column for the Details :)
Also in compact view you don't need the "More" button, pressing down on the remote works with out a bottom shelf, so that frees up some more room :)
Yeah that looks better.
hahah i was afraid that u would pick up on that  :wub:
I know what you mean, most of the time you don't need a title, I guess we could just make it a selectable option, Full or Compact.
The movie name is pretty important.
Removing the 'more' button might confuse users.
Or Disabled for those of those that want the old style. Choice is good! :)
but the more button is not really nessacary is it? u can get the same info by just press down cant u?
what does it exactly do roidy and what is gained by the extra space, is it just blank space/ fanart?
i wouldent even need the actors list cause i have it here
Unfortenally they are not clickable but still looks nice.. but i would prefer simular genre movies in that list :D
EpisodePrePlay.xml
http://www38.zippyshare.com/v/20592737/file.html
can i pls have ur brain??  thx man awesomeeee  :wub:
Well the "More" button gets you to the genre/actor pivots page. Removing it just gives you the extra space so the buttons don't look so close to the "Details" info. You can see in the 2 example images I posted, it just looks less crowded without the "More" button.
Sorry, I'm rather attached to it :D
This can be rached by just pressing down on the remote right?
Only if:-
1) You have a bottom shelf, which you do with the actors.
or
2) You use the "Compact" view.
I actually like the "Actors" bottom shelf, but it was taken out because actors was added to the "More" page and not everybody has actor images, making the shelf look kind of crappy :(
the pivot page is awesome though, hiding it from most users or it not being accessible is not :(
i agree it looks neater but at a price
Sure, but we're not stopping people from accessing it, it would just be removing the "More" button and making them press down on the remote instead :)
Here's an attempt at a Season Coverflow with artwork:-
http://www67.zippyshare.com/v/61419844/file.html
Only if:-
or
roidy
Yeah it looks awesome.. but movies would look even cooler ;)  (do u feel the peeks? :D )
f00b4r..
the pivot is nice but if its still thers while pressing down it wont matter if the button is removed right?
(edit rodiy just wrote the same)
