Fast forwarding and resume does not work
Hello,
I cannot fast forward or resume a tvshow. I only see the subtitles and sound fast forwarding but the image hangs at the point i started the fast forward. When i resume a tvshows it only shows the subtitle and the sound but there is also no image.
ATV3 - firmware 7.0
DNS: 192.168.2.1
Local IP PlexConnect: 192.168.2.1
PlexConnect version 0.5-4
Installed on DS413, DSM 5.1-5021 Update 2
PMS 0.9.11.7
Local IP PMS 192.168.2.1
Media file info:
Media
Video Resolution 720p
Duur 42:31
Bitrate 1151 kbps
Width 1280
Height 720
Aspect Ratio 1.78
Container MP4
Video Frame Rate 24p
Web Optimized Ja
Has 64bit Offsets 0
Video
Codec H264
Bitrate 1083 kbps
Bit Depth 8
CABAC 1
Chroma Subsampling 4:2:0
Color Space yuv
Duur 42:31
Frame Rate 23.976 fps
Frame Rate Mode cfr
Has Scaling Matrix 0
Height 720
Level 4.1
Profile high
Ref Frames 5
Scan Type progressive
Width 1280
Audio
Codec AAC
Kanalen Stereo
Bitrate 64 kbps
Taal English
Bitrate Mode VBR
Duur 42:31
Profile lc
Sampling Rate 44100 Hz
Ondertiteling
Taal English
Format TX3G
Ondertiteling
Codec SRT
Format SRT
I hope someone can help :)
Does this happen with all your files or only just one specific file?
Multiple files from different tvshows. Just tested a movie which worked great. Both movie and tvshow are MP4 with SRT subtitles.
Here is the movie info which works:
Media
Duur 1:48:16
Bitrate 1046 kbps
Width 1280
Height 688
Aspect Ratio 1.85
Container MP4
Web Optimized Ja
Has 64bit Offsets 0
Video
Codec H264
Bitrate 948 kbps
Bit Depth 8
CABAC 1
Color Space yuv
Duur 1:48:16
Frame Rate Mode cfr
Height 688
Level 4.1
Profile high
Ref Frames 4
Width 1280
Audio
Codec AAC
Kanalen Stereo
Bitrate 94 kbps
Taal English
Bitrate Mode VBR
Duur 1:48:16
Profile lc
Sampling Rate 48000 Hz
Ondertiteling
Codec SRT
Format SRT
