hello,
iOS 8? if yes, join the club:
No upgrade to iOS 8 for me :)
Please help :)
IF you want help then read the Pinned “Read before Posting” thread and post all the information requested in the how to report a problem section.
Your ATV model : apple tv 3 version 6.0
The DNS server set on the ATV : 192.168.1.44
The local IP address of the device that PlexConnect is installed on: 192.168.1.44
The device and operating system (including version number) that PlexConnect is installed on: Windows Home Server 2011
The device and operating system (including version number) that the Plex media server (PMS) is installed on: Windows Home Server 2011
The Plex media server (PMS) version number you are running (do not put 'latest'): 0.9.11.4.739
The local IP address of the device that the Plex media server (PMS) is installed on: 192.168.1.44
The PlexConnect version number: 0.5-dev
The contents of your 'Settings.cfg' file (this is created at first clean shutdown of PlexConnect, using CTR+c)
[PlexConnect] enable_plexgdm = True ip_pms = 192.168.178.10 port_pms = 32400 enable_dnsserver = True port_dnsserver = 53 ip_dnsmaster = 8.8.8.8 prevent_atv_update = True enable_plexconnect_autodetect = True ip_plexconnect = 0.0.0.0 hosttointercept = trailers.apple.com port_webserver = 80 enable_webserver_ssl = True port_ssl = 443 certfile = ./assets/certificates/trailers.pem loglevel = Normal logpath = .
Detail on the media file if it is an issue related to playing a media file:
This XML file does not appear to have any style information associated with it. The document tree is shown below.
A detailed description of the issue : when I resume playing a movie in 1080p I have only sound and no picture.I tested with two different pms (one on my mac pro and another on my windows server) and with different films without result. 720p pass without problem.
Thank you very much for your help! -
WIth high log enable plexconnect looping ..
PS : @drewbie thank you for the tip ;)
>>from media info: *.mkv
>>PS : if I choose DirectPlay instead of auto nothing works.
Well, you are playing an MKV file. ATV doesn't do MKV natively...
yes but if i play the movie it's works. Only resume is impossible.
my problem is the same as : https://forums.plex.tv/topic/79953-issue-when-trying-to-resume-a-movie/
