Fast syncing with iOS and macOS per USB
You want to go on a trip, and sync your favorite shows to the iPad? Your wifi speeds are really slow? There is a solution for that!
Do it via the USB cable! The speed might not be unlimited, but if the local wifi is also ■■■■■■ …
Step 1:
Connect your iDevice via USB to the Plex macOS Host and trust the connection.
Step 2:
Go to Settings<Sharing<Internet Sharing
Select “iPad-USB” or “iPhone-USB”
Detailed instructions
Step 3:
Disable Wifi on the iDevice and enjoy speed!
