Feature Reequest - Documentaries Container
Hey Guys,
I can't be the only guy out there having issues with documentaries. is it possible to have a 'documentaries' option that polls for both 'movies' and 'tv shows'
at the moment having a container for each is a bit annoying.
As Documentaries are not specifically labeled by thetvdb or by the movie metadata agents, having a specific container for it would be meaningless.
The purpose of the containers is to limit the pool where the metadata comes from, unfortunately for Documentaries it's a serious clusterf**k
Documentaries often follow a certain logic however.. The key thing being that they are often one off named shows, or they are a common series name with part x of x naming..
Having a media agent tuned for this by having a specific library section type probably could work better than what we currently have.
