Feature Request: Ability to browse all shared libraries
(Not sure if this is the right forum section or not - forgive me if I'm in the wrong place.)
Would it be difficult to enable users to browse a 'combined' library of all shared servers? I ask because if I want to watch a movie that I don't have (let's say 'Airplane!'), I have to check shared library A to see if he has it, then if he doesn't go to library B, then to C, etc...
It would be awesome if I were just able to see all movies available in any of the shared libraries, so I could see 'Hey, here's "Airplane!" Sweet!' and play it without having to check each shared server individually. If it's present on multiple libraries/servers, then provide the option to select which one to stream from or something.
Just a thought I had while trying to find Winnie the Pooh movies for my 20 month old daughter to watch.
as long as you have Search shared libraries checked ( most clients have it) then when you type in "Airplane" it will search all shared libraries at once
