[Feature Request] Add "Match" and "Fix Mismatch" option to web client home page
It would be very user friendly if we could manually match or for that matter fix a mismatch directly from the home page sections, such as Recently Added Movies.
Currently if you click the … on a title in the Recently Added Movies section, you receive the following options:
If a title is not matched or incorrectly matched, you must click on the title and only then can you manually match it. it would be great if you simply added the match/fix incorrect match option at the top level.
I see this is a moldy oldie thread, but I just noticed this same change in PMP. Up until very recently you COULD access the “match” or “fix match” option but now the only way I see it is to go into the actual movie detail page
Quite annoying! I used to fix a lot of movies right from my home screen!
Does anyone know about this?
Much of this was talked about here.
https://forums.plex.tv/discussion/306587/extra-step-for-match-to-appear-in-three-dot-menu/p1
I’m going to comment over there since it’s more recent…
