Is there any way you could add a feature on the Dashboard where “Recently added …” where you could UNMATCH or Fix Match? Sometimes, plex doesn’t pick the right thing and I have to physically go to TV SHOWS, or MOVIES, then go to the actual show, then I can repair the MATCH. It would be just more simpler to edit the match from the Dashboard! Thanks!
Darren
