Plex Web constantly getting update but it will be nice if you add the option of Match and Fix Match inside the drop down menu when you are looking at all your content and selecting the … on a movie and fix the matching there, instead of heading inside the movie and do the match there.
As of now this option it’s not there unless you open the movie and come out and then the option will appear on the drop down menu when you click on the 3 dot on the movie.
