[Feature Request] Add refresh next to library edit button
I would like to suggest a new feature that will ease the life of PMS server admins that run more than one server.
First of all I would like to say that I am aware of the functions of the Update Libraries scan from the drop down menus.
As it is now admins have to enter the specific library sections to get hold of the Update Library button so that they can start or cancel the update for that library only. I would like to suggest that you implement the Update Library button to the mouse over feature that you already have that contain the Edit Library button.
I have included a mockup that show how I picture the change.
![post-131068-0-13402600-1427891473.jpg|245x33](upload://gXc2mH801LUuR0pnKRsZ6zsVqfx.jpg)
The reason for this feature request is to save some clicks and page jumping if you just want to run a quick scan on a specific library instead of using the Update Libraries feature. If this feature can be implemented you wouldn't have to enter the libraries to do this task anymore. You would simply have to mouse over and click.
-S
I like it, would help me out.
You should really ask a mod to make your title more descriptive so people might have a better chance of looking.
Yeah I just noticed that I kinda made a mess of that. Thanks for the heads up ... now to find a mod :)
I changed the topic for you, if you want something else just send me a pm or leave a message
Awesome, got my vote!
