The options for importing custom certificates are quite poor in that referencing the exact path and even getting the certificate to a path on the server can be difficult. It would be beneficial to have an import function that allows either a pfx file or three seperate files for cert, key, and chain to be uploaded and imported with some kind of validation check to ensure the certificate functions correctly.
That’s actually something I don’t like.
It shouldn’t be difficult to convert this into an upload form and would make certificate management much more easier!
