Feature Request - Choose cinema trailers from [OTHER LIBRARY]
I’m simply looking for an option to tell plex where to pull it’s cinema trailers from as preroll. Right now it’s limited to only looking for trailers in the SAME library as the main feature.
I have a separate library just for trailers called “Coming Soon” that I would like to tell plex… hey… the preroll trailers you’re looking for, look in THIS library… which ideally you specify via drop down with a list of your existing libraries in the settings.
And yes… I’ve purchased a plex pass, twice now… and the trailers offered through this service are very bad… I have my own trailer files stored locally, I simply want plex to play them before movies in my “Movies” library.
Can we please see an update with this option? Thanks!
