Feature Request - Converting more than one item in parallel
Currently conversions only handle a single sequential queue. The premise is that each conversion takes up the appropriate amount of system resources to get its job done, but the reality is that a lot of resources are left on the table.
It would be great to have an option to set the amount of conversions to run in parallel
This would be amazing!
I’ve requested the same thing in the past as well:
Combining this functionality of converting multiple items in parallel with the clusterplex dockermod (GitHub - pabloromeo/clusterplex: ClusterPlex is an extended version of Plex, which supports distributed Workers across a cluster to handle transcoding requests.) you could convert in parallel across a swarm of transcoding nodes without overloading PMS itself.
