Thanks for the correction. You are correct as H.265 is still a compression. I edited my prior comment.
Regardless, now that MakeMKV can do DL-DV, hopefully PLEX can open this can of worms and let loose on DV playback for PLEX Pass Members. Of course, correcting a few bugs, like Hub management on NVShield Pro would also be nice.
No problem. I had noticed some others here had said the same thing about UHD discs.
IT WORKS
The very first time I started a DV movie it showed the badge for about 5 seconds and then the screen flashed and the HDR badge came up instead. I exited out and went back in and it stayed DV for a good 15 seconds, but I had to get to a meeting for work so thatās the longest I could test.
Iāll try watching some harder stuff (like Gemini Man in 60fps) later and post some updates!
This is awesome! I canāt wait to get home and test this. All my discs are ready to go into box and collect dust now.
PS. Plex should start tagging HDR10 and Dolby Vision movies as such instead of tagging like how it is now, 4K UHD, which is redundant anyway.
@Cannikin - please clarify what platform you are running this on?
This thread is about Android TV.
Thanks for the feature.
Iāve tried playing the MakeMKV samples on the FireTV Stick 4K and it only triggers Dolby Vision on the profile 7 FEL file.
Summary:
Profile 5 > nothing triggered
Profile 7, MEL > HDR triggered
Profile 7, FEL > Dolby Vision triggered, black screen (expected)
Profile 8.1 > HDR triggered
Iām expecting all of these to at least trigger Dolby Vision, as they do with ExoPlayer itself on the same device.
Iām using the new Plex beta (version 8.8.0.20999-beta) using the arm64v8a variant. I manually installed it on my 2019 Nvidia Shield Pro.
Iām playing MKV files ripped with MakeMKV version 1.15.2.
This is great, and it works!! I tried Black Panther on an Android TV and it triggered DV with full color and no audio issues. Birds of Prey did NOT trigger DV though. Iāll try a few more to see if any others work.
@anon18523487 - this thread was originally started specifically for Nvidia Shield 2019, not just Android TV. It also morphed into general Plex support for Dolby Vision in MKV (which is all platforms really).
@Cannikin - thanks for clarifying! This is exactly the information I was looking for. Cheers!
Did you sideload the beta? Betas are not available in the Amazon Appstore.
The Shield runs Android TV so any features available on the Shield will apply to all Android TVs. Specifics on if something works will depend on the device.
Feature requests are per platform or at least thatās the way they are intended. That way we can close requests are they are implemented. Itās impossible to implement some requests on some platforms so those requests would stay open forever.
If you need this for other platforms, please make a new request for that platform.
Yes I have installed the latest beta using adb.
If somethingās not working, weāll need Android app logs and the XML for that file to investigate.
I mean, youāre a Plex employee - Iām sure youāre aware that DV support should be on the other major platforms, right (Apple TV 4K, Iām looking at you)? Anyway, Iāll bow out and create a thread there.
As mentioned above, some features canāt be implemented on certain platforms due to either software or hardware limitations. Thatās why we request should be made per platform. If there is a definitely no, we can close those so people donāt keep waiting.
For example DV support on Web is not going to be possible, so if this request is for DV on all platforms, this request will never be complete.
I hear you. A thread was created with the Apple TV tag. Letās see if you guys can make it happen over there now. Iāll bow out of this thread, as I totally forgot it was only for the nvidia shield. Lol
Iāve created a log file for playback of the profile 5 sample and it contains this:
Stream has Dolby Vision v1.0 Profile: dvhe (5) L9
[VideoStream] Dolby Vision profile in the video stream is unsupported.
Which is weird, as thatās the streaming format thatās widely supported.
Attached log and xml.
p5.zip (7.8 KB)
Edit:
For the unsupported profile (7 FEL), it says this:
[VideoStream] Stream has Dolby Vision v1.0 Profile: null (7) L6
[FF] Video decoder doesnāt support dolbyvision (video/dolby-vision).
But triggers Dolby Vision with a black screen.
