Feature Request: Have Plex Store Album ID for a played track
Feature Request following this discussion thread > Dashboard reporting play history tracks from different albums to what was actually played
Currently plex will store the track ID and artist ID in the play history table but does not store album ID. To see this play a track and then query the metadata_item_views table afterwards. Example below …
sqlite> SELECT * from metadata_item_views WHERE id = 20705;
id     account_id  guid                                   metadata_type  library_section_id  grandparent_title  parent_index  parent_title     index  title         thumb_url  viewed_at   grandparent_guid                        originally_available_at  device_id
20705  1           plex://track/5d07cdbe403c640290f5d5fe  10             3                   Kate Bush          1             The Whole Story  2      Cloudbusting             1657032157  plex://artist/5d07bbfd403c6402904a65ce                           94
sqlite>
So why is this a problem. Well, full details are in post Dashboard reporting play history tracks from different albums to what was actually played but for summary I’ll quote from @OttoKerner
When a track is played, only its numerical track ID is stored. The same track ID can occur in several albums.
When a list of played tracks is compiled, Plex simply uses the album information of the first occurrence of the same track ID in the database. It doesn’t necessarily have to be the album from which you have actually played this track.
This then causes problems with the album in the dashboard report as per my other post.
Please consider adding this information to improve over all stats for play history …
