[Feature Request] Improved matching results
It would be much appreciated if the dialog for matching a movie could include more details about the movie beyond just the name and (sometimes) year. Other details that might help identify the correct match might be:
  • Lead Actor
  • Producer
  • Studio name
  • A simple link to the web page for the result.
I’ve recently re-loaded my entire collection after an upgrade to Windows 10. Many of the movies match automatically just fine, but others match incorrectly or not at all. Going through those has been time consuming due to the fact that after searching the dialog will often contain several results with the same name and either no or identical years. At that point it’s just a guessing game as to which one is correct. If you choose poorly, repeating the process wastes time, particularly if fetching the results is slow as it has to re-fetch them again over and over. Perhaps simply caching the results would help?
no update on this?
When having multiple movies with the same name its impossible to chose the good one:/
Cover and beginning of the resume will be enough for me
