When you use the match tool to try to fix a bad match (which is often) then when it pulls up the listing of matches it just shows the movie name, date and a score. We need more information to properly match many movies. At a minimum it would be nice if we have the option of seeing all the information that matched to that movie. Often the difference between 2 movies is a company name. There are countless times where the same movie name, year and score are used. Right now you have to select the match, wait for it to update the metadata and then determine if it was right.
Suggestion - show all the metadata for each potential match so a user can select the best match easily.
