I’m reposting @STaRDoGG and @sambarlick feature request post as I can’t find it here in the ‘Feature Request Voting’.
Feature Request:
Organizing multiple versions or editions of a movie into one item in the library. A version/edition or variant of a movie could be: resolution, director’s cut, a sequel of a movie.
The organization of the editions could be multi level. For example: The James Bond movies would get organized together into one item in the library. Under that main ‘James Bond’ entry you would see all the different James Bond movies. One version/sequel would then have, if existing, several resolutions SD, 720p, 1080p and cuts of the movie (theatrical, director’s, standard etc.) to pick from.
I believe this would declutter the library tremendously! Please vote up if you thinks so too!
The basic feature of this function is already build but not sufficient:
support.plex.tv/hc/en-us/articles/200381043-Multi-Version-Movies
The links to the original posts:
forums.plex.tv/discussion/202500/feature-request-merging-of-movie-variants-into-a-single-group
forums.plex.tv/discussion/184852/multiple-versions-of-the-same-movie
