[Feature Request] Mix Builder - Append newly generated play queue to currently playing track when adding/removing artists
Dear team,
When adding/removing new artists to a “mix builder” that is currently playing, it would be great to keep the currently playing track running and to generate the new play queue following the currently playing track.
Kind regards.
I’ll +1 that.
The mix builder would be awesome if it could be altered dynamically.
I use mix builder mostly during those late night listening/drinking sessions with my other half, casting to the shield.
Inevitably you think of other artists as you’re listening and having it keep stopping kills the vibe. If you could just add & remove on the fly that would be mega.
The dream would be to have it sync between devices so for example you have some friends over then anyone could contribute. Probably quite difficult to implement but can’t hurt to have it on the wish list.
Loving the new filter thingummy in version 3.4.0 BTW.
