It would be nice to be able to customize media optimization even further by selecting the desired container(s), video codec(s), audio codec(s), etc.
For example, the Xbox 360 supports direct stream, but not direct play. Therefore, I would select all containers available because it doesn’t matter. I would then select H.264 and AAC. There might be options for bit depth and level (or more).
