Feature Request: Multi-select to mark as watched/unwatched
Can we have an option to multi-select episodes to mark watched/unwatched?
Thanks for the suggestion!
Indeed, adding a podcast to PLEX but not being able to set your current position in episodes means a lot of work.
Yeah. Even a mark all listened would be helpful trying to switch over for people with long histories of podcast use :slight_smile:
You can mark all as played or unplayed already. In Plex Web, go to the podcast show screen and click the check in the upper right corner. It will ask you to confirm marking X episodes as played.
On mobile, the check box is also on the podcast show screen, to the left of the big play button.
