[Feature Request] Plan to support AWS S3 for media Library?
Hello is there any plan to support AWS S3/S3 external compatible provider?
The idea would be to choose the storage type at library creation (local FileSystem or external storage like s3…etc).
Thank you
I consider this is redundant to your comment in the related feature request (from good old “Plex Cloud” days)? If so… please don’t double-post – that’s considered spamming :wink:
Okay I’ll close, thanks :wink:
You should see my reply in the other topic.
