It is so aggravating to be 90% done with a mobile sync only to be interrupted and be forced to do it all over again. Some kind of way to resume an interrupted sync operation would be fantastic. One simple solution to this would be to change in the way the files are saved to disk. Currently, the entire video contained in a single file. I wonder if it would be possible to chunk the file during the muxing processes into smaller files that the player can read sequentially so it’s played back seamlessly.
2021 clean-up: duplicate
