[Feature Request] Plexamp Main Window Larger
I would appreciate the main window to be made available bigger if possible for those who would want it. I cannot scroll down the main window to see what’s up next on the playlist started on radio.
Otherwise, great use of the Gracenote suite and finally building music especially for Plex Pass subscribers. Finally, I pulled the trigger and paid for the lifetime Plex Pass subscription as a way to always have Plex. I’ve used it everyday for the past almost two years, it was time.
Pro tip: edit config.json file and you can put whatever size you want in there.
Thanks for the kind words!
